Center-Diff 4wd systems Swapped into CJ's
MomoJeep
Seattle
WA
I know some CJ-7's had "Quarda-trac". But are there late model systems that are a good swap into CJ's / Scramblers?
And the viscous coupler in many of them isn't known for longevity.
There's also the NP203 if you want to get old school...but it's not quite as "smart" as the viscous systems.
I'll look into that. I just think it'd be cool to have a lim-slip center diff that can also lock. This would be great on patchy ice/snowy roads.
Didn't quadra-tecs have a clutch-style lim slip?
This is a full time 4wd case also like a stock CJ quadratec. Both at one time had aftermarket part time kits available.
The NP203 was a wide open diff, if I remember correctly. And the case is rather large since it's a gear-to-gear range box, then a wide chain transfer box, then the bias diff housing/tailshaft assembly. The plus side is they existed in both driver and passenger drop variations, and also had kits available to nix the diff, or you could nix the chain box and just make a doubler.
The "viscous coupler" mentioned is a clutch type mechanism. But, it's not a differential. The viscous coupler is not mechanically connected by any other means than the clutch pack. When the clutch wears out or starts to fail you lose any and all means to transmit power through it because it just slips. It's not uncommon to see Quadra-tracs in front wheel drive only when the coupler gives up the ghost.
Are there any combos (Transfer case / axle) that could be fit pretty easily/minimum effort?
I would find a quadratrac full size Jeep like a Waggoneer from the 70s and get the whole driveline.
I have an offset Dana 44 rear axle if you're interested.
Appreciate the info and offer. I am a ways off from starting any type of project so I will have to pass on the axle.
Perhaps their longevity on the street is better. I have pulled/installed 4 quadra trac transfer cases in the same CJ7 in 2 years. Original was worn out/wasn't providing power to the rear. It was removed and replaced with a rebuilt QT with standard parts. It only lasted a couple trips before it had excessive slipping. It was replaced with #3 that had a part time kit installed. This one lasted 3 trips before the shifting mechanism started slipping. That was removed and replaced with #4. #4 has a different case with a different part time kit. Fingers crossed it lives longer.
This is on a CJ7 with a warmed 360, TH400 with OX lockers front and rear and 35" tires. It isn't treated nicely and it is a wheeling rig. The issues with #2 and #3 could have been install/adjustment issues. Either way, I don't have fond feelings for quadra tracs.
A worn out QT will make for really cool front wheel drive burnouts though.
I don’t know if this is helpful, but with the front hubs locked, any of the newer chain drive transfer cases seem to shift in and out of 4WD like butter. On Copper I would leave the front hubs engaged in snowy days, and drive in 2WD. I’d flick it into 4WD as needed. Our 2001 Cherokee with part time works the same way. I have a 1999 Grand with a 247- I’m not impressed with its operation in the snow. Takes way too long for the front to “automatically “ engage, and there’s no lock override.
Randy, is a D300 included as a "newer chain drive"?
You bring up an interesting point. When I was a kid I was driving a '75 & '79 CJ5 with the D20 TC's. They required full stops to shift in/out of 4wd. I am conditioned to only shift during a full stop. Are you saying a these later TC's are more like a "Shift on the fly" system? Or shift while rolling?
The quadratrac is Full-time 4wd right? No option to disengage the front driveshaft/axle?
The D300 is a close relative to the D20. It has a better low range, better bearings, and helically cut gears but operation is similar.
The newer chain drive cases are “shift on the fly” and that’s what makes them so nice. But- they only “shift on the fly” if the front hubs are already engaged.
There were(are?) Part time kits available. Also quadratrac also came in 4 wheel high only and there was an optional low range kit for them.
To elaborate on Randy’s description of the D300, it is a gear only transfer case. The chain transfer cases being described have a gear low range system and a chain that connects the rear output to the front output.
The gear cases are much stronger. The Atlas that is so sought after in hard core trail rigs is basically a beefed up D300.
I don’t know of any gear transfer cases being used in current production vehicles. The chain cases are just so much easier to shift, be it with a lever or a solenoid of some kind.
The transfer case in the Land Rover Discovery series 1 and 2 was a full time 4wd with an open center diff. They had a center diff lock that would lock the front and rear output together for off road purposes. This was accomplished by twisting the transfer case lever (only the series 1 cdl was connected from the factory, series 2 used the abs to control wheel slip). This is a gear case, but shifts really well.
Only issues in using this would be adapting it to a Jeep transmission and the passenger side rear drive shaft off set. Land Rovers have always had the front and rear driveshafts in line on the passenger side. They do this so you can approach obstacles knowing your differentials will both follow the same line. On a US spec car, they are in line with the passenger’s left leg.
