Front diff on wrong side for(most if not all) them and custom front axle needed.
And the viscous coupler in many of them isn't known for longevity.
There's also the NP203 if you want to get old school...but it's not quite as "smart" as the viscous systems.
This is a full time 4wd case also like a stock CJ quadratec. Both at one time had aftermarket part time kits available.There's also the NP203 if you want to get old school...but it's not quite as "smart" as the viscous systems.
I'll look into that. I just think it'd be cool to have a lim-slip center diff that can also lock. This would be great on patchy ice/snowy roads.
Didn't quadra-tecs have a clutch-style lim slip?
Are there any combos (Transfer case / axle) that could be fit pretty easily/minimum effort?
I don’t know if this is helpful, but with the front hubs locked, any of the newer chain drive transfer cases seem to shift in and out of 4WD like butter. On Copper I would leave the front hubs engaged in snowy days, and drive in 2WD. I’d flick it into 4WD as needed. Our 2001 Cherokee with part time works the same way. I have a 1999 Grand with a 247- I’m not impressed with its operation in the snow. Takes way too long for the front to “automatically “ engage, and there’s no lock override.
I would find a quadratrac full size Jeep like a Waggoneer from the 70s and get the whole driveline.
I have an offset Dana 44 rear axle if you're interested.
The D300 is a close relative to the D20. It has a better low range, better bearings, and helically cut gears but operation is similar.Randy, is a D300 included as a "newer chain drive"?
You bring up an interesting point. When I was a kid I was driving a '75 & '79 CJ5 with the D20 TC's. They required full stops to shift in/out of 4wd. I am conditioned to only shift during a full stop. Are you saying a these later TC's are more like a "Shift on the fly" system? Or shift while rolling?
There were(are?) Part time kits available. Also quadratrac also came in 4 wheel high only and there was an optional low range kit for them.The quadratrac is Full-time 4wd right? No option to disengage the front driveshaft/axle?
