'81 Scrambler - does it have a "brain"
DRdalequail
San Angelo
TX
I gather there were some substantial changes in CJ 8s from '81 to 82-86, e.g., wide-track, emissions. From what I gather from several posts herein the "ECM" (not sure what that stands for [Engine Control Module??} was not included in my 258 6-cylinder. Is that correct? Or, if it does have one where is it located?
It is my understanding that the ECM or "brain" was in 82.5 to 86 models. It was typically located behind the glove box on top of the heater duct assembly. Others with more experience than me may be able to give better insight.
AJ is correct that it is located behind the glove box. It controlled some distributer timing and the stepper on the carb along with the emissions. You will know if this does not function because you will have a hard time controlling the carb at idle and your engine will lack power due to the distributer not have enough mechanical advance built in. Computer controlled distributors only have 8 degrees of mechanical advance versus the older models with 12 degrees. This is the direct reason why most people complain about how slow their 258 motors are the then get blown away after switching to an HEI setup. If they went to an older factory distributor they would have seen the same power gains.
I can't be the only one that laughed out loud at "brain" in relation to CJs :rotfl:
Nothing at all against you @DRdalequail, just an amusing term when used for these old-school Jeeps of ours ;) What that brain did on these things is really, really simply compared to anything modern. I'm trying to come up with a good analogy and a better term, but I'm not thinking of anything good right now.
It's like comparing an amoeba to a human, I guess :bacon:
I read that about the mechanical advance, too, but not all of them are like that.
Around post #254, my bone stock CA emissions 1985 model:
The OEM mechanical advance mechanism was good for 16 degrees total mechanical advance, BUT the original tight springs would not let it go past 8 degrees.
I swapped in lighter springs, graphed out the mechanical advance, and now it performs awesome.
You are correct, most of these "eBay/Made in China/Performance" distributors have lighter advance springs inside of them, which lets the mechanical advance come in sooner, which does make the engine more "peppy".
I have some posts somewhere where I had to map out the advance curve on an "eBay special HEI distributor", it was so far out of whack it was not funny.
Around post #74:
This Jeep also had a bent push rod, fuel pump packed full of crap, and rotten gas in the tank.
Again, I always take the "holistic" approach to performance :D
