Goofed off some this morning, but still got what I wanted to accomplish today completed.
More tools all over the floor, pulling the front output shaft yoke off the Dana 300 to investigate a leak.
It has been leaking since way before JeepAddicts purchase, note the cool yellow/red stain on the aluminum from the nasty old gear oil:
This yoke is grooved too bad to repair. The front yoke is down low, completely submerged in gear oil, so if I even have the slightest doubt about a yoke, I swap in a new one. Cheap insurance on a PIA leak/repair. Also note all the glitter.
Part number visible on the existing oil seal. I think someone tried to fix the leak, but added more shims on the back side on the output shaft, increasing the end play, causing a bigger leak, due to the yoke plunging in and out so much.
Good thing I keep some inventory!!! I had a new spare yoke, a couple of leftover output shaft seals, and plenty of shims from all the Dana 300's I have rebuilt over the last 10 years!!!!
I cleaned the front of the case up, installed the new output shaft seal. A little tricky with the skid plate in the way, but not too terrible. In the below picture, I am pointing at the "circle" that the metal dust shield on the OEM yoke wore into the front of the aluminum housing. The front output shaft had excessive play for awhile, that had to make some racket!! That is where all the "glitter" on the old yoke/grime on the front of the transfer case came from!!!
Setting up the dial indicator just to get a base line reading. I already knew the end play was excessive, and it is, at close to 10 thousandths:
To adjust the front output shaft end play, pretty easy. On the back of the transfer case, below the fill plug, there is a thick steel plate held in position by four bolts. Remove the bolts, the plate/shims/bearing race/and more nasty old gear oil crap falls out.
According to the FSM, this is the end play you are looking for. At this spec, there is no "in/out" movement that you can feel with your hand, and the bearings turn smoothly.
This transfer case had a 30 thousandths shim and a 6 thousandths shim. I pulled the 6 thousandths out, substituted in a 1 thousandths, and installed the new yoke.
Checking the end play, within range:
I went ahead and removed the 1 thousandths shim, sealed it up, done. With approximately 2 thousandths end play, no in out plunge, bearings still spin free.
Not sure why this happens to the front output shaft bearing end play? These bearings feel fine. I have had to readjust the front output shaft end play on numerous Jeeps, including on transfer cases I had recently rebuilt? On the rebuilds, it is usually minor adjustments.
Oh well, easy enough. The rear output shaft feels great, so that made me happy!!!
Refilled the transfer case with gear oil and called it a day.
With this chore complete, I can reinstall the driveshafts, then reinstall the wheel hubs, adjust the rear brakes, a few other odds and ends, then finally put the new wheels and tires on.
That's it for now!!!
