- W-S
- NC
Can I bring mine next for the things that I just can't seem to find the motivation to complete?
So, I have the front and the back, time to fill in the middle.
My initial plan/sketch/idea:
Some clamps, the center hanger I used, one of the two 18" pipe sections I used, off the shelf muffler.
The muffler I used. A hair small, but it was on the shelf. I think I have this same muffler on my green Scrambler.
The original rusty center hanger, and the replacement I bought and used:
The new center hanger turns the center bushing the wrong direction. It could be cut apart and modified, but it ended up working perfectly with the off the shelf hanger I used in the middle:
I just clamped it together, it can be welded.That all clamp together or are you welding the seams?
Good to know. I really, really suck at welding. I've played around a bit, but never been able to do much with any success. Cheap HF mig with no gas/ flux core isn't exactly the right machine to be learning with, but maybe some day....I just clamped it together, it can be welded.
I will say this - once the clamps go on, it will NOT pull apart.
I would love to do just that, but just don't have the free time right now. Welding is one of those skills I really need to obtain.Not to bomb this thread...but Adult Ed in your area might have an evening welding course. Ours typically shows the basics and then if the individual has a metal project they learn as they go on that.
Or, crack the exhaust manifold.You must use different clamps than I do (or are just better at assembly).
My exhaust was all bolt on, and on more than one occasion I had to pick up the rear section after it was yanked off by either a big rock or a mesquite tree. But then again, if it had been welded on, I might have had a gash torn in the muffler.
