IMO, the 4 cylinder is worse then the 258, with regards to vacuum lines/feedback stuff. At least the 258 is longer, so it spreads this crap out some. On the 2.5 it is just all bunched up!!!
I was going to do a better job of marking where stuff goes, BUT not sure it is right? So, I will need to spend some time during reassembly to ensure everything is reconnected properly, and no damaged vacuum lines!!
In the picture above, I was able to disconnect/separate stuff, 1/2 dumped over the valve cover, 1/2 dumped on to the driver side fender, leaving a big hole to access the intake/exhaust manifold.
And of course, drama:
Snapped off the upper power steering pump bracket to intake manifold bolt. Steel bolt, aluminum intake, almost 37 years, seized up. No other bolts snapped. I "should" be able to drill this out, re-tap, and/or Heli-Coil if necessary. If not, no big deal, this upper bolt is really not needed. This set up is similar to a 258, and I run my green Scrambler (4.2 with 4.0 intake) and ran my red Scrambler for 30k miles (4.2 with 4.0 manifold) without this upper bolt, no problems. BUT, I would like to fix it, if possible.
I thought this orange gasket was aftermarket, maybe not?
Picture showing all the crap I dumped over to the driver side fender:
All the crap I dumped over the valve cover:
The AMC 2.5 only uses 7 bolts to hold the intake/exhaust to the head. All 7 bolts were loose. Also note how it only has an intake gasket, no exhaust gasket.
I did NOT separate the intake manifold from the exhaust manifold (EGR crossover tube holds them together). The reason why - I AM SCARED TO. I do not have much confidence that I can successfully remove the cross over tube with out destroying it. With a 258, no big deal, you can find the tubes easily. Not sure about the 2.5. So, for now, I slid the joined intake/exhaust manifolds off the head, removed the gasket, and then slid it back on. I will clean the head, install a new gasket, call it good.
The new gasket is a combination intake/exhaust manifold gasket:
I prefer to run an intake/exhaust gasket. Some do not. The head/manifold surfaces are good to go on this engine, so a quick clean up, new gasket, torque it down, call it good.
Close up of what I presume is the OEM intake gasket part #:
So:
Loose carburetor to intake manifold
All 7 intake/exhaust manifold bolts loose
Major exhaust leaks
Unplugged ported and manifold (not pictured) ports on the carburetor
#2 cylinder push rod dangling in the breeze
Timing WAY out of whack
Completely fouled out spark plugs
Rotten gas/rubber fuel lines with holes in them
Presume to be gunked/stopped up carbureter
I am amazed it ran at all!!!!!!!!!!!!!!!!
Previous owner: "Just pump the gas pedal 5 times and it will fire right up and drive great".
Delivery Driver: "There is something seriously the matter with this thing. I have driven thousands of cars, this one is non-op/F&*ked".
The truth is somewhere in the middle
That's it for now!!
