So, thank you all for the info.
The picture of the TSM was the CJ7 one.
I found the CJ7/CJ8 one... and printed it out.
It had some measurements so I tried... and they weren't close.
The biggest issue with the picture is that this is a CJ7 picture with some scribble of an CJ8 length on it for one of the numbers.
The distance between the eye holes for the spring hangers grow with a CJ8, so you really need an actual picture of the Scrambler frame.
I used the CJ7 TSM for my actual CJ7 and the numbers were pretty much spot on.
The Scrambler however, wasn't close.
So, I started down the path of is the 4 cyl frame different? Is the Scrambler I have different? and then looked at older pictures and this was just a stock Scrambler... so at this point, I need an actual frame dimension picture specifically for a CJ8 for reference... or
I will use the old frame for reference.
Now that I have the center point of the old frame and I know that it is sitting on the frame I want... make a new "center" on the new rails, cut off the ends measure out from that point to match the old and start down the path of tacking together the frame front/rear, put the mounts on, flip and do the spring perches and such... and a ton of holes in the bottom for all the hangers, bump stops, sway bar, skid plate for the trans, engine needs and finally the front shackles (and the rear as well).
That is another whole task... right now I just need a square frame that resembles the old one from the top
