Rear sway bar on 4.5 RE springs
But the relative movement in this setup for a bar that size is completely mismatched. There’s never going to be much any twist in anything short of a serious off-road flex. Even then, not much at all.
Useless.
Totally agree!
Plus, why would anybody think a scrambler needs a rear sway bar? These things should NOT be driven like that. (I could think the world cab or full length top equipped vehicles might benefit from one, but even that is a marginal use case.)
I've thought about adding a rear sway bar to my red Scrambler :twocents:
Soft springs, sits high, loaded down, 70+ on the highway, it sometimes feels a bit "soft" in the corners. Under 70, no issues.
When I drove the tan Scrambler at 80+, with full hard top and Detroit in the rear, a rear sway bar would have been nice :twocents:
Not needed, but would have felt more stable for sure. Didn't the YJ's/TJ's come with rear sway bars? I know they have the track bars front and rear, could have sworn my LJ has a rear sway bar??
I have the ADDCO sway bar on my blue scrambler that was set up as a daily driver. I noticed a big positive difference in the handling on country roads. Only issue I had is the spring mount is really close to the rear shocks.
Any pictures of how you mounted the frame brackets?
😂😂😂 Holy crap. I had one similar to this on one of my parts scramblers years ago. I have no idea how well it did or did not work though. I absolutely was not driving that Jeep. It was extremely rotten. I had to throw on several extra rachet straps when it was on the trailer to keep it together. On mine the leaf springs were both bent where the sway bar clamped on. It was basically the same as this except I don't think it had a hoop in the middle. I do get some people wanting a sway bar for added stability, but this is just dumb.
This is interesting.. because.. (a) I have wanted a real swaybar because a hardtop, gear in the back, and a roof rack gives me a fair amount of rear sway and I want to go to softer springs. And I would want it to disconnect for off-road.. and (b) I have seen aftermarket swaybars for CJ's before, but they function the same as the front. Not like this one...
THIS looks like what you have...?
Here's a proper one..?
Looks exactly like the one I have.
Have a Hellwig rear unit on our JKU and it seems to work well. I’d suggest throwing a coat of paint over the powder coat though. Only thing on that Jeep that’s rusty other than the driveshafts.
Is it quick-disconnectable?
