I have a set of Rugged Ridge, I have not installed them yet. But, I don’t think there are other options. Crown parts are generally trash.
There is a thread on here somewhere showing how you need to start in the middle and work towards the outside when installing, and don’t expect OEM quality.
Intermittent problems are so GRRRR! Is the PCM still throwing a Code #51 Lean Condition when the engine stumbles? Did you or HESCO adjust the timing on the PCM or is it at the factory setting? I know you can subtract 6 degrees of timing in the PCM but it takes one of the factory Jeep/MOPAR...
www.cj-8.com
The Rugged Ridge flares work well. The rear flares do have a front and back, like the previous posters mentioned!!!!!!!!!!!!!!!!
