- Joshua
- Tx
Figured I'd post this in electrical section as most of my questions have to deal with the stock harness.
Looking like I'm going down the EFI route. Want to have better reliability in the mountains this summer. I have read everything I can read about the Sniper/Hyperspark system and seems very straight forward. However most of my confusion is about the removal of unnecessary items that it replaces. Here's my thoughts on my wiring harness and vacuum system and would like a review and any insight please.
1981 main wiring harness. Pre computer non CA jeep. Luckily I don't have to deal with all the nutter stuff. I traced every wire on the firewall block to its source in the engine compartment and labeled below.
The (code) on each line corresponds to the wiring diagram I'm referencing. Might scan that in and post that later tonight.
I also have the motocraft ignition module below the brake booster and the Idle Speed Control Module or Idle Speed Switch on the passenger fender. It's my impression a lot of these wires will be deemed obsolete.
The IGN module as the following wires
Red&Blue - they both go to the firewall block
Purple/Orange/Black - these go to the distributor
Green - to coil and the ISC
The distributor and the coil will be replaced with the sniper system so essentially this box can be cut out. I need to verify but the Red wire going to block BW will be my 12v switched for the sniper unit. The blue is spliced and also goes to the starter solenoid so that'll spliced wire will stay.
The ISC has these following wires
Orange - switched power from the manifold heater relay
Brown - to wiring block BY (controls idle speed for a/c I believe which I dont have)
White w/ black stripe - TES air cleaner sensor
Red w/ white stripe - Control vacuum solenoid on valve cleaner/wiring block CX
Red w/ black stripe - SolVac on carb
Pink - Control val solenoid
Green - Ign module
Black - air cleaner TES sensor/ground on engine block
All of these seem obsolete as well. These are all essentially a function of upping or controlling the idle. With removal of the associated vacuum related items I see no reason to keep anything from this box. Thoughts?
Vacuum systems
I plan to keep the OEM air cleaner. The first trap door on the cleaner that closes to keep the fuel vapors when the engines off will be disabled. Not needed with the sniper I've researched. I'd like to retain the TAC system and should be able to.
My confusion is with the TVS the EGR and the CTO systems. What's the consensus on keeping these vs eliminating the EGR? If I remove the EGR there's no reason to retain the TVS (temperature controlled vacuum). I plan to keep the Canister for fuel tank vent.
Fuel
Going with the 15 gallon in tank module. Stock fuel line is 5/16ths. Sniper recommends 3/8s. I've seen reports of people running both. What's the consensus?
Power
Is it necessary to get a higher amp alternator for any of this? I don't have much to power other than my winch. I may wire some lights and a better radio one day.
Starter solenoid
None of the sniper install schematics have the starter solenoid pictured. Wires CX and AX both go to the solenoid. AX is blue and that's the ignition so that'll stay. CX also ran to the coil, ISC and control vacuum solenoid. I don't see any inputs or wires to go to the Sniper CD coil so would all these wires be removed from the solenoid?
I appreciate everyones input. I believe I have a good grasp on it but as it's my first EFI swap I want to cover all my bases before I dive in and I'm all ears
Green - Ign module
Vacuum systems
Fuel
Power
Starter solenoid
