Question About Relay Next to the Starter Solenoid
NoVaCJ8
New member
Haymarket
VA
Is anyone familiar with the relay in this pic? It activates as soon as I connect the battery, but I cannot tell what it is turning on. Something is draining my battery overnight. I put an ammeter in line, and the Jeep is only pulling 9 milliamps when shut down, but this relay is most of that. BTW, I replaced it with NOS, but it behaves just like the old one. Also, still has original Carter carb, which I know has a lot of electrical gadgets on it.
Thanks
Might be a headlight relay used to direct power the headlights from battery instead of having all the current run thru the switch in the dash. Helps to brighten up the headlights as there is less voltage drop. NOT factory original.
What doesn't work if the relay is not plugged in?
An AMC 4 cylinder I worked on had a similar solenoid in a similar location for the choke. IIRC it was tied into the alternator, i.e. would only energize choke when alternator was spinning.
This is a thread I did awhile back on a 1985 CJ7 with the 2.5 4 cylinder engine, might be helpful:
Thread '1985 4 cylinder Base Model CJ-7' https://www.cj-8.com/threads/1985-4-cylinder-base-model-cj-7.52267/
It was for me, too. First AMC four cylinder I worked on, lot's of differences between it and the 258.
One of the best things I did when I was running the MC2100 was go to a simple part store manual choke.
If this is a choke relay and is activating as soon as the battery is connected, something is definitely wrong with how it's wired, right? No relay should be activated at all times.
That relay does not operate "normally", kind of strange. I went through this when I was working on JeepAddict's '85 CJ7.
It’s stock. I couldn’t figure out what it controls on mine. My choke wasn’t working either and finally added a Weber carb and a manual choke.
Thanks everyone. I will investigate the electric choke first and report back.
If its the choke relay then this is it, ground to one side, should only switch on when the alternator is charging.
If its on all the time then i would suspect the alternator has an internal "leakage" issue making its way through the internals.
The 4.2 has an oil pressure switch that does the same job as this one which is a bit easier to diagnose, the 2.5 is clearly a different setup.
Thanks for posting that. I bought a new (rebuilt) alternator from Advance Auto a month ago. I was convinced that the new alternator was bad and draining the battery. So I returned it and they replaced it with another new (rebuilt) one. Both behaved the same way with that relay. I had to give them the old alternator as a core, but I wish I had it back to test with. It wasn't necessarily bad, but I wanted a new one because I was installing an HEI distributor.
I observed the choke while plugging/unplugging the relay and I do not see any movement or anything else. The engine is cold, and the choke is closed as it should be. I will keep working on it.
Assuming we are on the right path here then you could try removing the plug on the alternator and see if the relay goes off?, if it doesn't then its probably something to do with that resistance wire thats causing your issue, if it does then its a possible alternator issue.
Problem solved. I called tech support for the alternator (Drive Works), the guy who answered knew immediately what the problem was. This new alternator is a self-exciting (one wire) alternator, with the two-wire side plug blocked off with rubber cover. I incorrectly assumed that the cover was for shipping purposes, so I removed it and plugged the factory harness plug into it. The guy said to simply unplug it, which I did and problem solved, and I learned something in the process.
Thanks to everyone for your posts!
