2tall's Scrambler Journey
Negative battery cable was definitely on its last leg upon further inspection. Thankfully it lasted long enough to get us back home yesterday.
Stiff and corroded
Fresh replacement from the universal selection at O’Reilly’s. Perfect length to reach the engine block, miss the headers, and not have too much extra.
Went for an afternoon cruise today and enjoyed the early spring weather in south Mississippi today. Noticed I’m about 100 miles away from the 500 mile break-in oil change on the diffs today also.
I decided to dig into the brake system project today. Starting to realize I’m not the greatest at documenting my work as I go. Got everything attached to the firewall pulled out, including the pedal assembly.
Old stuff wasn’t exactly old but I was never happy with how it worked. It was a cheap power set up from probably eBay or Amazon.
Here’s where I didn’t document the majority of the work. Originally it was a manual pedal assembly with the clutch pedal removed or cutoff. A while back I bought an automatic assembly from Dead Jeeps on eBay. The post for the brake rod on this pedal didn’t work at all for the new set up. Ended up drilling out the post and welding on a larger and longer bolt, making a bushing for the rod, and installed the return spring from the original pedal. Lots of tweaking and fitting for a couple hours, but I have the correct pedal now. That’s a leaf not rust btw.
Loosely installed the new bracket/linkage, booster, and Wilwood master. Worked on adjusting all the push rods and linkages to get full travel and good pedal position.
Got everything set up to my liking and secured appropriately. Definitely a more pleasant looking setup, hopefully the performance matches.
Moved on to the rear brakes. Previous owner did a rear disc swap on the 14 bolt. They worked ok but less than stellar install. Weird soft lines, odd routing, and crap for securing the hose to hard line connections.IMG_5629.jpeg
Pulled the calipers and swapped in the new units. Mocked up the braided hoses and welded in the tabs for securing the hoses to the axles. My welding wasn’t pretty but it’s going to hold.
Pulled calipers, hoses and hard lines from the rear axle all the way to braided hose at the diff.
So I should be ready to do new hardliners from the frame/axle hose to the caliper hoses tomorrow.
Finished plumbing up the rear with new copper nickel lines between the braided hoses.IMG_5640.jpeg
Made a little bracket to bolt the hose to a diff cover bolt.
Installed a tab on the frame to secure that end with the correct style clip and routed the vent hose up.
Cleaned out powder coating of the threads in fhe proportioning valve bracket to get it ready to mount.
Pretty cool bolt together set-up once it’s together. Made up new lines there as well. Not sure why I did the coils but I always see it done that way.
Moved on to the front disassembly. More weird hose selection, routing and securing.
New calipers and braided hoses mounted. Deciding and checking where to weld the securing tab.IMG_5645.jpeg
Pile-O-Junk removed
Whipped up another bracket for the front frame to axle hose and got it secured at both ends.
Got hard lines made to connect to the caliper hoses. Re-used some of the coiled protective sleeves on the front lines due to the routing.
Got the master bleed, mounted and hooked into the proportional valve. IMG_5650.jpeg
Paint had dried on the hose tabs while I messed with the previous step, so I got the hoses connected, clipped in and tightened banjo bolts at the calipers.IMG_5651.jpeg
Hooked the vacuum bleeder up and got good fluid flow. After some initial checks that everything is good, took a short trip down the road. Pedal is much firmer and more responsive. The old set up had lots of pedal travel. Waiting on a helper to give it a final bleed the old fashioned way and hopefully this project is wrapped up.
Life has been busy the last few months and not much love for the Scrambler.
But I got married.
Honeymooned in Utah.
Matt’s Off-road Recovery in Hurricane
Zion National Park
Cool Rig in Zion
Fab Rat’s shop in Glendale
Red Canyon in Dixie National Forest in our rental we nicknamed Ruby the Rubicon.
Bryce Canyon Nation Park
Capitol Reef National Park
Finally got around to wrenching on the Scrambler on the 4th of July. Did the annual engine oil and filter change. Finally hit the recommended 500 mile break on the gears, almost a year later, so did the front and rear diffs also.
New fuel filter and some fuel treatment, not sure it helps but I use it.
Also decided the single 9” booster from the kit o recently installed wasn’t quite working out. It got swapped out for a dual 9” from the same company.
Double the thickness and much less effort.
Super useful tool when messy with boosters and master cylinders.
Still need to do a full test drive and see how the brakes are feeling but that’s coming soon.
But I got married.
Zion National Park
Cool Rig in Zion
View attachment 114184View attachment 114185
Congratulations on getting married. Next month is 40 years with my bride. Wishing you the same
Awesome stuff!!! Love the kiss photo with the Scrambler. I bet it was jealous.
Thanks! To most people’s surprise including the Scrambler in the photos was her idea not mine.
Thanks and congratulations to the 2 of you on 40 years! Big milestone
Congratulations on your marriage! Renee loves the scrambler and cruising with her in it is my jam. May the road (and trail) rise up to meet you and looking forward to seeing more of your adventures together.
Thanks! We both certainly enjoyed our cruising together when the weather is nice.
Did a little tinkering on the Scrambler this morning, nothing major just detail work that hopefully makes it a little more reliable.
OEM dipstick and tube from a 2003 2500 with 4l80e fit pretty well. Hopefully more accurate and secure than the previous ones I’ve tried to make work.
Matches the OEM engine oil dipstick I previously installed from the same model year.
Also whipped a quick and simple support bracket for the intake tube. Thick piece of aluminum flat stock from the scrap bucket.
Bolted to the cylinder head with a random bolt bin find. Stainless socket head and nyloc nut on the tube’s tab with some fuel hose for a sort of bushing/isolator.
Took the wife out to lunch in the Scrambler and cruised around some. Decided to swing by the Cat scales on the way home. Full tank of fuel, tool kit and bottle jack, and the both of us. I estimate 4490 without us, lighter than expected.
4,760 pounds loaded up for a week in Michigan. Tools, camping stuff, full tank of fuel.
Shit, I only have a 4.0/AX15/Dana 300/AMC 20 and Dana 30 :eek:
Maybe one of you should start a thread just for Scrambler Weight for easier reference should anyone want the info? Unless there is already one some where?
