- Dexter
- MI
Looks strange with the master cylinder on the 'wrong' side...![]()
Speaking of, the fuel pressure regulator is going to live right behind it. Needed to make this call to finish the fuel lines. This will allow me to put the pressure gauge right into it and skip the AN take off fitting that I had planned to use.
I’m running the fuel lines on the opposite frame rail for stock to get away from the exhaust. I’ll reuse the stock line for the vent to the charcoal canister on the other side.
And since Sam set this up to have the stock fuel line location I’d have to modify his fancy stainless return line. The 90 degree bend runs the wrong way. I could cut it and do a compression to AN fitting to go the right way. (I plan to sleeve the stainless line in a DEI heat sleeve.)
Now to finish the fuel lines. Filter going high on the frame where it’s easy to get to.
