Alaska Postal Is Home
Major Jack
Zillah
Wa
Started right up and drove it off the ferry and 10 miles home. "I KNOW - THIS THREAD IS WORTHLESS WITHOUT PICTURES." Our camera is in the wife's car. I will get some pictures up this evening or in the morning.
Door on drivers side won't stay shut. I did have a bungee cord to keep it from flying open. Can't get the barn door open. The drivers (Pass) side floor board will need replacement. I did a short inspection and frame looks real good. Areas I could see of the body look sound other than that floor board. Once I get it pressure washed I will have a better idea.
He was concerned about the transmission. Put some atf in and it shifts solid. Just have to get new trans filter and aft in to see what happens.
He was right about wipers and headlights being DOA. Add dash lights to that list. All the gauges except oil pressure work.
The body doesn't appear to have ever been hit. Did the ole thump test an got a metal sound in all areas tested.
All in all, I am pleased with the purchase.
As I said, will get pictures posted.
Captain Jack
I tried to post pictures but had a problem. Started a thread asking what I did wrong.
Got a bit of work done yesterday. Moved the battery from the floor board to the stock location.
Started spraying down bolts, nuts etc. in preparation for removal.
Got the barn door unlocked and found the bottom hinge was rusted and not swiveling. Started spraying it down.
Discovered it has an engine heater, a battery heater and another plug (110) that goes down the back of the block and disappears. Does anyone know what this is?
The carb. is the stock Carter. It's in sad shape. I am trying to decide how to deal with this. I have read about the MC2100 change over. What really catches my attention is the GM - TBI adaption. Only problem is, we don't have any wrecking yards in Juneau. If you have a car that is DOA. It goes to a metal recyclers and eventually ends up a cube or flattened. They can't sell parts as they are not licensed with the city as a wrecking yard.
Tried Craigs List and E-Bay with no luck finding a complete setup. Need a complete setup including TBI, wiring, sensors and computer.. You know the drill. It would be a big help if someone out there willing to find one for me and mail it up?
Crawled under and checked for bad rust. The only problem areas is the drivers side floor (Ordered the panel last night) and a small spot on the cowl.
Springs are a rusted mess. I don't think the PO ever washed it. I will clean the the springs as best I can and paint. I will replace later with a lift. Nothing too high.
Will post pictures when I figure out what I am doing wrong.
Captain Jack
Other than rebuilding the carburetor and just puttering around with small things I can accomplish easy, I am putting the Postal "On Hold." I just returned from Seattle and a visit with a neurosurgeon. 15 years ago I was paralyzed from the waist down. By the grace of God, after surgery, I was able to walk again. The last two weeks, I have experienced symptoms like I had before. A MRI and other tests have confirmed my fears. I will be having surgery soon.
Please keep Dawn and I in your prayers.
Captain Jack
So sorry to hear that Jack, thoughts and prayers headed your way my friend.
Take care of the important stuff, the Jeeps will be there when you're ready.
Just picked the Postal up with new exhaust from manifold back. Quiet inside now.
My neighbor, who is a Jeeper sent me to NAPA with a list of items to pickup. I came home with the following.
Cap Adapter FA139
Cap FA136
Rotor FA159
Coil IC24
Plug Wires 700230
He pulled Jeep stuff off and installed the above. Even with the junk Carter BBD the Postal started like a dream. He explained, the larger cap with the brass contacts along with the hotter coil sends more juice to the plugs. Also, no flash between terminals. The 8MM wires help too. We put premium Champion plugs in gaped at .045 to make better use of the hotter spark.
He also said we needed to do the Nutter Bypass. Any thoughts on this?
I am going to go with a MotorCraft 2100 carburetor. I want to get rid of as much of the junk under the hood as I can. Anyone else like this one?
Oh yea, is there a good place to buy a brake line kit with all the hard lines? The Postal has a lot of surface rust and this is a bad area. I'd just feel a whole lot safer with new brale lines.
Last but not least, what rear disc brakes are you using and why.
Thanks in advance for your feed back. I need to get mechanical done and then will address cosmetics.
Captain Jack
Nice! You just did the TFI upgrade on the dizzy, it's a nice upgrade just like the HEI except that you keep the stock ignition box. Nothing wrong with either option, just different, and you should be set for a long time on the ignition side now :thumbsup:
I wouldn't bother with the nutter if it's running ok, just find your 2100 and install it. Agreed on getting rid of all the crap you can under the hood!
On the brake lines, can you compare to a stock scrambler? with the RHD I'd think you're looking at at least extending them on the front end, but might want to be sure that there's no other major differences. I personally would just go get bulk hard line and bend/flare your own if it's going to take any serious "adapting" to get the LHD lines to work.
No disc brakes in back, just waggy drums here :smokin: If you have the $$$, I'd just get the complete kit from SSBC (think that's them) and be done. Spankjr just picked up a kit and posted a pic I think.
