FLCJ8
- Palm Bay
- FL
The Mopar MT fluid I used is similar to the Syncromesh/Amsoil. In fact, they are approved equals for the Mopar stuff. This stuff burnt in the first T5. Smelled slightly burned, discolored, no "oily feel" left, felt like water
On the NWC T5, there is not a 100% clear cut factory approved fluid, EXCEPT the AMC stuff, which Penzoil says there Synromesh is an equal, which I failed in the first T5![]()
Not sure this has been discussed before, but it's interesting.
http://www.pro-forceperformance.com/t-5_history.htm
Especially this part:
Transmission Fluid
BorgWarner allowed each manufacturer to choose the lubricant for its particular application, but it seems that BorgWarner's recommendation was Dexron-II ATF from the very beginning. GM adopted the Dexron, as proven by the stickers placed on each transmission. Ford adopted Dexron as their official fluid, as proven by specifying the ATF product in their original 1983 and 1984 Field Service Manual publications. For some reason, AMC chose to continue specifying gear oil instead of ATF. The early style of Dexron is no longer available. Generic ATF such as DEX/MERC is a suitable substitute. A Ford dealer will recommend their Mercon-V ATF which is also a good substitute.
Many Internet sources insist that gear oil should be used in the Non-World Class T-5, but the documentation above clearly reveals that both Ford and GM chose to use ATF from the start. Using gear oil in a Non-World Class transmission will not significantly damage the transmission, but many times, due to Internet confusion as to what is, and is not, a World Class T-5, gear oil has been mistakenly used in the World Class units.
Update on Dexron VS Gear oil for NON-World Class T-5's:
Dexron-III ATF replaced Dexron-II in 1993. While Dexron-III meets or exceeds the previous specifications, the viscocity of Dexron-III is thinner than the original Dexron-II that was specified for the NON-World Class T-5. This thinner fluid is fine for the World Class T-5 with the lined synchro rings, but the NON-World Class T-5 with the brass synchro rings needs a thicker fluid to work optimally. As a result, Tremec has specified 30W MOTOR OIL for the NON-World Class T-5's. While Tremec has not published an official document about this, it is confirmed by an email dated 1/9/2012 from a Tremec Engineering/Support employee.
WARNING: Using gear oil or motor oil in a T-5 with the composite lined blocker rings found in the World Class T-5's will destroy the blocker ring linings over a period of a few months rendering those synchronizers useless.
Raymond, how does this compare to your research?
