Start: 59,431
Home: 64,855
Total =
5,424 miles, start from home, end at home
Changed the oil/rotated the tires at 63,166 when I first arrived in Michigan, thanks again Toby for letting me use your garage
Only two "issues":
1) The nut that holds the clutch pedal swing arm to the big under dash bracket fell off while in Kansas. In hind sight, the clutch felt like it had too much free pedal when I was leaving Colorado. This progressively got worse. I inspected the under hood/body linkage while at a gas station, it was all good. While crossing Kansas, I noticed a lock washer and nut on my floor mat. Pulled over, reinstalled the washer/nut, problem solved. When I got to Michigan I added a lock nut, problem permanently solved.
2) Passenger side rear wheel had some "spray" on the outer side, inside dry. Not gear oil or grease, 90% sure of that. Pulled wheel off, axle tube end dry, hub flange dry. No idea, I thought dog "P" because it was not really a "spray art" pattern like you get with a bad hub seal. I cleaned the wheel off when I first got to Michigan, no repeat UNTIL I got home. It was dry all through Michigan, Indiana, Kentucky, and Tennessee. I first noticed this at my last gas stop in Alabama, south of Montgomery. I had just driven through some monsoons, so who knows. Cleaned it up yesterday, will monitor for now.
It was great seeing old friends again, and meeting new ones
I will post up the few pictures I took in the next few days. Another 'adventure" successfully completed
