Started my pre-National inspection/maintenance shake down late last night, finished up this afternoon:
Forgot about this little Redneck Ray fix from Hot Springs, lost one of the away bar disconnect pins, easy fix:
Lost the correct Dana 300 shifter nut, just red lock tited a regular 7/16 fine thread nut on, no big deal:
So I pulled all four wheels to make the following maintenance work easier:
Oil change, clean K&N air filter, rotate tires, pull brake calipers and check all four corner wheel bearings, check front and rear axle fluids, check AX15 and Dana 300 oil level, grease tie rod/drag link/sway bar fittings, clutch linkage, front and rear driveshafts, and all suspension bolts. Plus a bunch of other stuff.
Found that one of my rear brake calipers is missing the upper spring assembly that helps release the parking brake cables:
Not too concerned about it now, but will need to find this part sooner rather than later. No idea how I lost/broke this part?? I will contact SSBC and see if they can help me out. I also will need new rear brake pads in the next 5-6,000 miles, need to track that down, too. I wouldn't mind finding a spare set of rear calipers since they are kind of odd ball, and they are well past 10 years old, close to 70k miles on them.
Was able to grease the rear CV without fully removing the drive shaft:
Last year when I replaced/repacked all four corners wheel bearings, and installed all new front spindle components and front axle shaft u-joints, one thing I forgot to do: grease the upper and lower ball joints. The lower ball joints can be greased anytime, the uppers can not. I am running Dana 44 sized u-joints in the Warn front axle shafts, no clearance to pull the plug, install a zerk, and grease the upper ball joints with the axle shafts installed:
So, took a four hour detour and pulled both front axle shafts, installed zerks, greased the upper ball joints, reinstalled the plugs, reassembled the front end.
I really do not know how often these should be greased, probably before almost 70k miles!!! For sure wouldn't hurt to hit them up anytime the front shafts are pulled, or servicing the wheel bearings. My ball joints have no play, nor do they stick, so I am assuming they are fine.
Miles right before I left home tonight:
Will break 70k before I get back home.
Left my house, made the 2 hour trip to JeepAddicts house in Prairieville, La, tonight, no issues. Fingers crossed I'm good to go. Figure if it just made it 2 hours non stop at 75mph, should be fine for another 8.5 tomorrow!!!
That's it for now
