- Biloxi
- MS
Yesterday's update.
Since I already wiped it down, went ahead and hit the front axle/steering linkage with a light coat of Rustoleum. The front looked rough compared to the rear axle.
Finished up the rear suspension installation:
I thought both my rear shock lower studs were OK, they were not, both bent. I had spares on hand since this is a known problem. It's not that these parts are weak, they just mount down low so I tend to smash them into rocks/tree stumps/pedestrians/etc.
Installed new bushings in the front spring packs. Some long bolts/washers/nuts, a wrench and an impact made short work of this chore. The two ends of each spring use a different size sleeve so two different sized bolts were used.
And the front suspension installation complete:
And the pile of old parts/hardware:
That concludes this little project. I still need to snug up the main eye bolts/shackle bolts once the Scrambler is back on the ground, plus hit all the suspension zerks with the grease gun.
