Put the rear driveshaft back in, interior back together, didn't feel like waiting until tomorrow for a gasket to arrive, so bought a sheet of Felpro cork gasket material and made my own Dana 300 inspection cover gasket.
Traced the cover, used a 5/16 hollow punch that fit through the covers bolt holes to make the holes.
I still had the old gasket, still in one piece, so it was easy to trace out the inner cut line. I used sharp scissors to cut the outer line, X-Acto knife with new blade to cut the inner line.
My 5/16 holes were a bit too small, so used the 3/8 punch to open up the holes, give me some wiggle. The chamfer end on the punch will center up in the smaller hole. Worked well.
Ta Da.
Fits really well.
One hole was a hair off, easy enough to trim it out with the X-Acto knife.
My home made gasket installed, seems to fit well. Being cork, I like it more then the typical thin paper gaskets used here.
I used the Aviation Sealant on both sides of my cork gasket, thin coats. I used the hardening sealant on the one cover through hole, and on the drain plug threads.
With the cover reinstalled, skidplate and transmissions mount(s) next, 99% finished.
Going to let the hardening sealant cure overnight, then add gear oil tomorrow, that should be it for this little project, hopefully!! With rain all weekend, no big hurry to finish.
I had to install the clocking ring as a spacer for the 300 to slide onto the AX15. Then realized, yes, I could get rid of that rear "hump" in the OEM skid, gain some belly clearance, still haven't done it
I figure a few more big rock hits on the rear of that "hump" and I'll have a redneckray flat skid
I wish that skid extended to the rear another 2", I actually have a small dent in the Dana 300 inspection plate right next to the drain plug
So, it's been a few days, and I have probably put around 300 miles on this Scrambler since the Dana 300 intermediate shaft swap. So far so good as far as any leaks, but being a Jeep and a Dana 300, I'm sure it is just a matter of time
Oil change and tire rotation before this summer's adventures. I was going to work on the Scrambler outside to get out of the hot garage, but of course it rained.
Checked on few other recent repairs while it was down.
Pulled front brake calipers off, wheel bearing adjustment still good.
Front inner axle oil seals still sealing.
Rear axle drive flanges caps nice and dry.
Dana 300 98% still not leaking. Slight dampness around front output shaft adjustment shims/plate on the rear of the case, but never a drop or drip, so good to go.
Even though it will be a trailer queen this summer, I like to keep it ready for anything, you never know.
