As promised Photos of my new scrambler .. or CJ-8
I have the majority of the "new" 258 assembled minus the oil pan and valve cover. I need to decide on a few components and would like some input from the pros!
I have a complete DUI distributor that came on the scrambler it has the HEI cap and has a set of nice livewire plug wires.
I also have a converted original distributor to team rush or TFI i think. this came on the replacement engine.
I have a remanufactured carter carb that came on the scrambler
I also have a motocraft 2bbl with a monkey rigged throttle linkage, this came on the replacement engine.
I have to pass emissions in my area, so that will play a part in my decision.
I plan on running a factory power brake air filter assembly ( i am trying to source one from a 4.2l YJ). I will need to fabricate an adapter to run that with the 2100 but it should not be a big deal.
right now i think i will run the DUI dizzy and the motorcraft carb.
thoughts?
I made some more progress this weekend. I installed the oil pan on the "new" 258. I also pulled The old 258. scrambler is looking a bit bare.
I spent the past couple weeks working on the wiring harness and getting everything finalized to fire up the new engine. i also had to tear into the column to replace the ignition switch due to lost keys. while i was doing that i noticed that the slip joint in the column was loose so the shaft and the wheel would pull out of the housing. i measured the shaft length i needed, i pulled the shaft and tack welded it to keep it tight.
I temporarily bypassed the fuel tank and lines until i could clean out all the old gas. running on a gas can, i got it fired up and everything seemed to go off without a hitch. i had the wife with me as another set of eyes to look for leaks etc.I used a bottle of comp cams break in oil for the flat tappet cam filled with 5-30 and off it went for a 20 min cam break in. I set the timing at 8* and it seemed to run well for the break in. I shut it down and drained the oil and changed the filter, topped off the coolant etc.
this weeks project is to remove the tank and flush it, replace the rubber line connections to the rollover check valve etc. once i get that cleaned up i will get it running off the tank so i can start to check the driveline. I still need to put together the headlight buckets (for some reason the P.O took them all apart including springs etc.) the turn signals and run lights. all the other electrical works including all guage lights.
sorry for the bad cell phone pics!
Excellent:cheers:
I am running that same valve cover on my red Scrambler, watch out for the included oil fill cap, mine was loose/would leak. I can't remember the part # for the replacement I used, I just remember it was a hair too big, and I had to sand it down:thumbsup:
Keep up the good work:cheers:
When you change the rubber fuel lines out, go ahead and put in the high pressure fuel injection rated hose/clamps, just in case:twocents::thumbsup:
Cobra, that '5 of yours is looking great in the background.
After seeing the top-notch work on your '5, I'm looking forward to seeing what you do with this Scrambler!
Nice! You made the right call on using the DUI dizzy IMHO :thumbsup:
