Hi, Sorry I'm joining late... I just saw this.
Can I offer a different diagnosis and perspective?
My humble 2 cent opinions for your consideration:
1) I believe your calipers are NOW reversed (even though you say you have pressure).
That is, they are reversed now that you put the L-stamped caliper on the Right passenger and R-stamped caliper on the drivers side.
2) Why then do you have pressure? There are different procedures for different combination valves. Also different procedure if you use a combination valve bleed tool or not.
I suspect that when you went to re-bleed the brakes after swapping the calipers, you stumbled upon bleeding them correctly using the "non-tool" bleed procedure. (See my references below to my 2020 post).
Here is my support for my opinions above.
1) Support for the statement: The calipers as installed now are reversed. L belongs on the Left (Driver) and R belongs on the Right (Driver)
The Bendix 2238366 (L/R) casting was used on the following vehicles. Only the 1981 Scrambler had it.
| AMERICAN MOTORS | AMX | 1978-1980 |
| AMERICAN MOTORS | CONCORD | 1978-1981 |
| AMERICAN MOTORS | GREMLIN | 1977-1978 |
| AMERICAN MOTORS | HORNET | 1977 |
| AMERICAN MOTORS | PACER | 1977-1980 |
| AMERICAN MOTORS | SPIRIT | 1979-1981 |
| JEEP | CJ5 | 1978-1981 |
| JEEP | CJ7 | 1978-1981 |
| JEEP | SCRAMBLER | 1981 |
If you go to Rock Auto and examine the photos of every manufacturer's listing for the 1981 Scrambler, you will see that every manufacture displays as "Front Right" and image of your caliper that you have now installed on your Front Left.
https://www.rockauto.com/en/catalog...cid+l6,1183890,brake+&+wheel+hub,caliper,1704
Separately but related, Is your Scrambler (and/or axle) a 1981? If not, you might have the wrong calipers too.
2) Reasoning for:
a) The reason for the brakes not originally having pressure is because your Type W combination valve's metering pin was not properly pushed (depressed) when bleeding.
b) The reason why your brakes NOW appear to have pressure after multiple bleed procedures is you unknowingly correctly performed the "Non-Tool" bleed procedure (see 2020 thread reference below).
Our 1980s Scramblers have
Combination Valves which "combine" the
proportioning and
metering function into one unit. Additionally to make matters worse, Jeep CJs over the years had different versions of combination valves and different manuals had different instructions regarding whether to push or pull the pin when bleeding.
If I understand you correctly, you used some sort of tool to remove the metering pin?
If yes, that is wrong for the style (Type W) combination valve in the photo you posted (at least wrong according too the FSM).
The square-ish style body (Type W) in your picture is the same as the stock one that is still on my 1985 and was used in the 1980s. (Note, this is different than the rounded-style body used earlier in the 1970s.. the metering pin is treated differently during bleeding).
The Factory Service Manual (FSM)'s original shop tool is one that it slides OVER the low-profile hex nut that the metering pin resides within. By grasping the groove right behind the hex nut, the part of the tool flush with the face of the hex nut depresses the metering pin. which requires the pin to be pushed.
Here are various write-ups on this subject I posted in 2004, 2009, 2019 & 2020:
Here is my 2019 post (for when using the bleed tool) is the most concise regarding bleeding with a photo of a simple tool you can make that depresses the metering pin (which replicates the functionality of the OEM service tool):
https://www.cj-8.com/threads/brake-bleeding-frustrations.50266/#post-419550
Here is my 2009 post that best explains the procedure when you do NOT use the tool referenced in the 2019 thread:
https://www.cj-8.com/threads/soft-pedal.22119/
That is, you can bleed rear brakes on a type W combination valve (when you have a substantial amount of air to bleed)
WITHOUT depressing the pin. To do so would require bleeding in this sequence:
- rear right
- rear left
- front right
- front left
- rear right (again)
- rear left (again)
Here is my 2004 post which is a longer but gives more of the backstory on the Push vs. Pull debate on metering pins.
(The answer is that there have been different styles over the years and only the FSM can be relied upon...
NOT Chiltons or Haynes. 1970s were pulled and 1980s Type W are pushed. But unlike the FSMs, the Chiltons and/or Haynes never made that nuance change in their manuals during the 1980s).
https://www.cj-8.com/threads/brake-adjustment.7547/#post-44081
Here is my 2020 post that is interesting info regarding a port on the Type W valve. Some have experienced leaking there on NEW type W combination valves:
https://www.cj-8.com/threads/leaky-combination-valve.50425/#post-423506
Just my 2 cents
Thanks for entertaining my thoughts,
Jim
