CJ8 as a DD??
Rob S
Corning
NY
Hey guys (&gals). Was curious how many of you use your CJ8 as your DD?
I am considering trading off my XJ for an 8. I do realize I will be going from pwr windows/locks, AC, CC, yada yada.. But I always wanted an 8. I have a line on a clean one, with V8, 33's, hardtop, and am seriously considering swapping the XJ for it and using it as a DD, figured I would get some insight from you guys. I did have a few CJ7's as DD years ago, but could use an update from those currently using theres as a DD. TIA
mine is a daily driver....as long as its not snowing...i like my antilocks on the truck when its snowing
If it's in good condition, there no reason you couldn't use one as a DD. The problems start when you try to use a junker (anything) or an un-maintained vehicle as a DD.
Scott,
Maybe it's a northeast thing, but snow is my favorite time for the CJ (had a 7 last winter, did not get the 8 until a few months ago). Man, the fun I had (and will have).
I used the scrambler as a dd in college. Just put the hard top on in the winter. But I also had a 98 dodge sitting in the driveway for when jeep broke. But most breakage was from offroad useage, or poor college student not replacing things he knew were bad.
I've used mine as a daily driver for 5 years and it never let me down until I had a 350 put in it (poorly wired...). I loved using it a daily driver when it had 32" baja radials, 258, and a t-5. Rode smooth and got plenty of looks, plus it is real fun those few days out the year that it snows in Oklahoma.
Mine is my DD right now and will continue to be for a good while. Been a DD since 2000. Now it gets 80 miles a day min. You just have to keep up with the maintanence. Take care of it like it is a 20+ year old vehicle. IF you think something needs some work, do it. Since you are looking at a unit that has had a 350 (I am assuming) dropped into it, check the entire driveline. Previous owner may not have worried about longevity and thus things may be, uh, worn.
Get to know your parts store guys too! It still can be cheaper driving an '8 everyday than a 20K vehicle, but there are other costs you need to be aware of and ready for.
Good luck.
Daily Driver
I use mine as a daily driver. I am the opposite when it comes to snow. Mine stays in the garage on snowy days. The ole suburban does great in the snow.
Anyone can have an XJ, but very few have Scramblers.
Thanks
Butch
Thanks for the info, more is welcome. The 8 I am looking at has a AMC 360. I have built and drove Jeeps all my life, very familiar with the upkeep. Just wondered if any 8's are still being used as DD. I am in the North East so winter is an issue. If I remember correctly my CJ7's had the crappiest heater in the world, any one remedy this? I heard a Blazer fan motor was a good fix?
As long as you have another vehicle if the CJ decides it wants to stay home that day ;) :D
Easy to fix with the Blazer motor upgrade and a new heater core. Mine will toast you on the low setting.
I second the heater...mine is OK now, but I had a CJ-7 with the Blazer upgrade, that thing would cook you out of the cab.
I would strongly recommend buying it and servicing it immediately (before you sell the Cherokee). Typically, these things are old and have been moderately abused. Mine was in great shape, but had never had the tranny fluid or axle fluid changed (23years old and nasty). So, count on going over this thing with a fine toothed comb to resolve any maintenance issues, then enjoy driving.
I will re-post my "cheat sheet" of what I try to do when I look at an old vehicle:
https://www.cj-8.com/forum/showthread.php?t=12166&highlight=axle+joints
Check (replace if you can afford it)
tie rod ends
ball joints
wheel bearings (front and rear)
universal joints
axle joints
brake rotors
brake calipers
brake pads
wheel drums
wheel cylinders
brake shoes (with hardware)
belts
hoses
complete tune up (plugs, wires, cap, rotor, fuel filter, pcv, etc)
tires
shocks
flush radiator
alignment
drain/refill axles
drain/refill transfer case
drain/refill transmission
oil, oil, oil...
Remember, these are all wear items and the rig is 20+ years old. This will take care of the main stuff right off. It will help ensure you have a good base to start from (good steering good stopping good control). Then the only real suprises will be along the lines of a major uncontrolable (water pump failure, alternator failure, starter failure, clutch failure, master cylinder failure, steering box failure, motor failure, etc.).
Small upgrades that I have found keep it running smoothly include a DUI (or equivalent) ignition upgrade and Weber 32/36 carburetor. These legally eliminate the problematic emissions system and increase performance with savings in MPG...
twmattox said:
...and Weber 32/36 carburetor...
Or a Motorcraft 2100 (much cheaper in most cases and by most accounts easier to tune).
I have read that about the Motorcraft...but what I have also read is that they have problematic (though easy to repair) powervalves. When they go, you get a very rich running condition, till repaired.
From what I understand, the Webers, though difficult to get set up, are trouble free when done...(they are supposed to increase MPG a little too).
Daily driver here...but as soon as I can get either my Jeepster or my Baja running, the Scrambler goes under the knife...axles, ect. It's a great driver- comfortable, handles well, and with the 350 it's a great runner too. 14 mpg with 36" and 3.73's.
Just to chime in on this. I have been driving my 1981 since 1991 everyday for the most part. My heater works great in all conditions ( I must have gotten overly lucky on this) It get to hot in my short cab even when it is below zero outside.
On the carb issue. I have a 1981 CJ-8 carter BBD no computer or stepper motor attachment to it. It runs great and has never been an issue at all. I did get it super dirty and had to clean out the pickup tubes last summer, but that isn't a big deal. I would take my 81BBD over a weber anyday due to not having to mess with it all the time. I have thought about going the Motorcraft 2100 .08 route if I do any upgrade. You can find one of those carbs for under $100.00 and it is less tempermental then the weber.
I like dirving the Scrambler so that is what I drive.
Good Luck!
TK
