Hey guys!
So I'm going back up next weekend to the garage 2 hours away to unwrap everything and document every part I have. The crates are at least 100 pounds each so it may take a while. On top of the crates, there are also random tupperware boxes with miscellaneous parts and other stuff I'm probably forgetting.
Anyways, my goals for this build are to make it a little more aggressive and capable than my current scrambler. Nothing close to a rock crawler, but just something more ARGHHH! I currently have an 81' daily driver which I've posted around the forums and it's a very mild build, i.e. 2.5 inch lift, 32's, stock 4cyl engine, and aftermarket replacement parts. It pretty much looks original to someone who doesn't know jeeps, and that's what I was going for. Although I will drop a 360 in it (once i finish this engine rebuild which is taking forever), there is not much else I plan on doing to it. This 'new' jeep however is a different story. Since I already have a daily driver, I don't need to worry about gas mileage which is great! I'm thinking a 4.5" lift on 33's. I'm going to break apart the 350 TPi to get an idea of it's condition, hopefully I could use that and really make it a beast! If not, I have another 360 that I got a month ago for a steallllll so that could always be rebuilt and get dropped in. I would also like to throw on HD bumpers and tire carrier as well as some other little goodies like a winch, lights, and a sound system (wow!) but that'll get figured out in the next couple weeks.
I'm am struggling on one thing though. I can't decide where to put my postal top. Once it's on I don't really plan to ever take it off. They're not so simple to install/detach from what I've read. So I'm considering putting it on my daily driver and maybe install AC so I can run it even during the summer. If not, I will put it on this build and just make it a overlander beast! Just can't picture that. What do you guys think?
This is my first time tackling such a major project, my other scrambler was a frame on restoration where I just replaced parts that were already installed so not much skill required there. The extent of my creativity was put into building some custom troop seats. I guess my first question to you guys would be where do I start? I'll probably put the lift on to the chassis and rebuild the axles so that I can at least have a rolling chassis. After that, what's the next step? I don't quite know the process but I sure do learn quick! Thanks again for all your support, and let me know your opinions!!
Brando
