Re: the real truth
FELNTPSY said:
What's goin on here Eric....are you looking for a tow rig or what!!???
Aww, you got me. So what if it happens to have a 360, trailer brakes and a hitch? Does that mean it will be able to tow stuff???
I managed to take a peek tonight, we were out shopping near to where it's sitting (it's at a shop, not his house), so we went over tonight before I go to check it with the seller tomorrow morning.
There is rust, bubbling and visible in spots along some body seams and the rain guttering. Both doors are solid, some trim pieces missing where he swapped in the power windows and locks, rubber matting on the floor, seats worn and cracking but nothing duct tape and seat covers won't fix.
The rear tires are nearly bald, fronts are ok. I'd want to put new ones on in short order.
It was dark, so I couldn't see too welll and didn't climb under. No visible fluid leaks but I only know it's been in that spot since the 8th (same spot the eBay pics were taken).
No low TC, at least I didn't find the lever in the dark. Interior is in pretty good shape, original stereo, gages and clock.
Engine compartment looked pretty clean, might be a slight power steering leak but there didn't look to be any oil on the block, again, i couldn't see too well. Saw the 360 sticker, couldn't see the number on the block though.
Looked to be RTV used as a sealant when the exhaust manifolds were put on... that seemed odd to me. It was squeezed out from when they tightened it down.
Belts looked ok, couldn't see too much else and had to run to a party.
We'll see how it drives tomorrow. I might offer $1000 and see what he says.
What's a rebuilt 360 and a tranny rebuild go for these days?
I'll let y'all know as soon as I can after I get back to work after the shakedown/meeting with the seller tomorrow.
Don't forget I have the barganing position of knowing that he didn't get a single bid on the eBay auction too!
