FSJ question
Truck
Manassas
Va
I'm thinking about selling my DD (honda del sol), since I moved to Va I've been riding the metro and only driving it maybe on the weekends. I figured I might as well sell it before it is worth less three years from now. I saw a Grand Waggy for sale 89 111K, for $2400. So my questions are this. What are these GWs worth? Would it be a good CHEAP tow rig to haul scrambler & parts around? The wife is tired of me using here mini van to haul my trailer and parts around..hard on the van. And no I don't haul the full scrambler around with her van. I was thinking of a GW because that is what I saw, it has strong 360 in it, & good platform for CJ-10 pickup build I would love to do some day.
So any thoughts on the questions above..
Truck
I know people who have used these for just that purpose. I'd say go for it.
Your other option for the use you mentione would be an older model pickup with a nice big engine. If you're not too picky about the body, you could probably find one for a fair bit less than you're talking about for this GW. Just a thought.
Without seeing that GW it's hard to know what it's worth but I would say that I have seen nice ones go for less than half of that amount.
I am putting my 80 cherokee up for sale. It's a base wide trac, 33's, 360,T18a, NP208, rust in areas but no rot for $2300.
You can see pics on the cherokee page of my website.
Yeah, check out the ifsja.org board. You can get an idea on value there.
My '76 Cherokee Chief (360/TH400/Q-trac) ran me $825, and was a pretty solid North Carolina truck. It just needed new rear flares, minor bodywork, and a paint job. The motor was a little tired, though.
I will say that it towed stuff VERY nicely.
Craig
If you want a good cheap tow rig, get a 88-94 f250 or 350 with the non-turbo 7.3 diesel. They're cheap. Then take it to a shop and have it tuned, because the timing will be behind, and it'll make close to 20 mpg empty, and pull very good.
Yes, it will make a good tow rig if you are not worried about fuel consumption. Had a friend that would tow 8K-10K of logs out of the woods and pastures with he GW. Only problem he ever had with it was the transfer case.
The price seems high unless it is in near mint condition. Had a friend buy one for $250 for the axles. The seller drove it 200 miles to meet them and then they drove it another 240 miles home. Never had a problem with it, body was dent/rust free. Interior was decent, not all torn up.
A more typical price around here for a decent GW is about $1,500.
Seemed kind of high on the price..saw a '90 in paper today for 1900. Both are auto tranny, I assume tranfer cases were the same .. push button 4wd. If you guys think this will tow okay I may pursue..I figure there has to be a high school kid at the school up the street that just has to have my little del sol.
If I go for this any idiocyncracies I should look out for on these beasts.
Truck
Hmm...I own a 90 and have parted out several others. It's about as stout a suv as you can find. Problem areas are...
1. Lousy gas mileage. Don't expect over 10-13 on it's best day.
2. Check the frame for rust especially by the drivers frame rail,
silt tends to trap moisture by the tank and the frame rusts out.
3. The tailgate window switches both on the dash and in the gate are a high fail item. Likewise the rear window mechanism, and the wiring where it goes through the bottom of the tailgate. The harness flexes there and wires tend to break in the insulation.
4. The carb on later models is problematic, an older 2100 bolts up.
5. The roof rack bolts will allow water to seep onto the headliner, causing sagging.
6. Late models used a motorcraft ignition "box", I'd suggest
replacing it with a MSD. (did this on mine, with a TFI coil).
But...D44's front and rear in later models, usually with 3.31 gears are plenty strong. And the turning radius is awesome, way better than a Scrambler! The seats are extremely comfortable, although rear access is a bit tight. The back seat is fully removable, and alot of stuff fits in! And, it feels alot smaller than it is, but it has enough weight to tow respectably.
There's a sweet 91 here for $1095.00! Oh, I have a good hood and a great full set of burgandy leather power seats, console, and back seat. Windows and trim too!
Good luck, if you can afford the gas, they're great rigs!
Thanks for the input Randy..I saw an 88 on IFSJA for $1000 in Herndon..right up the road. If you have experience with these I could send you the link and you could give me your opinion.
As far as gas milage is concerned, I will not drive this often as I am commuting on the Metro to work everyday. Main use as a tow rig, weekend errand runner while scrambler is in pieces, and eventual base of possible CJ-10 pickup truck wishful thinking project.
Sounds like a good deal on 91..just wrong side of the country!!
Truck
Truck- just saw your reply, checked the link, and saw someone bought it. Was it you? Looks ok, but that skid on the gas tank is right where the frame rusts through. I couldn't really tell from the pics. Too bad you're not closer...that one for $1095 by me is sweet. They have an 88 for $895 also...I run across them real cheap all the time.
Let me know if you bought it!
I didn't get it..I had sent him an email to go look while I was awaiting your response. He never went back and checked his email or looked at IFSJA board so he sold it to carmax for almost nothing yesterday. I got an email from him this morning saying he checked his email and saw my msg and wishes he'd of checked sooner. Oh well..The bad part is that any of these in my price range I would have to go get and or I would have to work on. I don't have time to do that because it would take away from my scrambler time that I really want to get going..I would like to be done by next wheeling season.
I will continue to keep an eye out though.
Thanks for the information.
Truck
Yeah, probably better...that was a $250.00 Jeep, around here. I really didn't like the rust on the frame, I think you would have to do some major welding there. Plus putting it all back together... Too bad...they're really neat vehicles. When they were new they were the "Flagship SUV" to own. I think in 1990 they were 28k new! Can you believe that! keep your eyes open, another will turn up. Watch out for that rust, though... Oh, and check around all the window rubber for rust too...
Seems rust kills more of these than anything else!
(There are aftermarket frames available!)
