Gary R
- Arlington
- TX
Weekend Progress (and a milestone!)
Made some progress over the weekend. Got the new windshield glass installed,and got the windshield/frame attached to the tub. I also did a ton of wiring! The wiring is actually quite fun, but just takes time. I bought a universal harness without the factory ends alread terminated on each wire. This way, I can cut every wire to a specific length for the perfect fit. The only downfall is that there is a lot of soldering involved. But again, it's time consuming but fun at the same time! A few of the wire bundles have a bunch of wires: one is for the ignition switch on the steering column, and the other is for the turn signal/horn switch on the column. A bunch of wires to solder on each connector! Before I shut down the shop last night, I had fully terminated both the ignition connector and the turn signal connector. In addition, I had already wired everything 'firewall forward' (starter, ignition wire, battery, grounds, etc.) So I figured, let's see if any of this wiring works! I temporarily installed the battery positive cable and gave the key a quick turn...the motor immediately spun over about a half a rotation- before I let off the key...SUCCESS! At least my ignition wiring is working! Then I hooked up a test light to my turn signal wiring (not yet terminated to the lights) and I have blinking turn signals and hazards! This harness is great, and I'm having a blast doing it! In addition, it is comforting to know that every wire is brand-new, and by doing all of this in my own shop, I will have a very good knowledge of ALL the wiring, should I have any electrical issues down the road. Here's a photo of where she sits as of today...more wiring this evening:
I have Flowmaster 40-series mufflers installed behind 2.5" pipe, that are supposed to sound really sweet
