cchambers
- Sioux Falls
- SD
Taking out a new CLEAN trans and transfer case is way better than the old oil soaked units at least.
I've had to redo stuff that I was sure was fixed on my CJ8 alot after the rebuild. I just put my tub back on the frame and starting to tackle the breaks now. I'm having a tuff time finding the rear break line with the block the bolts to the axle right now. Do you have a good source?
Better luck to you
