Giving it a Jolt
gr8dain
Hater of Electronics
Ashburn
wow. have not checked on this in a while. Looking great. Can't wait to see how it performs when done.
Chamba
Not obsessed: Focused.
Vero Beach
Any further progress on a hydraulic clutch? I converted mine using a YJ pedal tree and Novak slave when I whacked the ax15 in my 8 (it's getting hard to find 4 cyl CJ7/8 pedal trees these days). I've been very happy with the results.
Kane
Berlin
ct
When I converted to my AX15 and hydraulic clutch I just drilled a hole into the mechanical clutch pedal lever and it worked great for 4 years until I pulled it.
certifiablejeep
Definitley Certifiable
Bedford
NH
The YJ pedal setup is a little more rigid as it has the "arm" that goes from the assembly to the firewall and through it... makes it a bit more tight with wiring if you run a clock, but overall gets rid of some of the flex... and allows for the hydraulic setup with the piece already on the pedal to receive it...
Those YJ pedal setups are out there, just not as plentiful as the CJ ones.
RockTractor
Albuquerque
NM
I used a the CJ pedal assembly. With a little effort, it can be made to work quite well.
Unmodified assembly showing natural position of push rod;
Small piece of steel cut to fill in the location where the pivot will be:
Steel welded in and new hole drilled:
New SS pin made from 1/2 bolt:
Final assembly:
Chamba
Vero Beach
Here's the little brace cb is talking about on my conversion
RockTractor
Albuquerque
NM
Nice. I never knew that existed (and even had a YJ pedal assembly in my old CJ-7).
I don't think that would be too hard to fab up and add to a CJ assembly if needed.
Silver Member
As I understand it, early YJs used the CJ style brace, latter YJs used a brace with wider spacing on the master cylinder.
YJ vs CJ Pedals
certifiablejeep
Bedford
NH
OK, I was talking about inside the tub/firewall, not the engine side... but yes, there is a bracket on the other side of the firewall as well.
I was referring to the arm that goes from the pedals through the firewall... it is shown here.
It is connected to the left of the pedal assembly and goes over and up through the firewall... like an arm/brace.
FLCJ8
Palm Bay
Sorry, been awhile. I have made some progress on wiring, pedal placement, and others but big stuff happens soon. Batteries arrive Monday. Will post pics later.
Glad to see you back.
Looking forward to getting back on topic...
not sure how this sidetracked.
timo439
Portsmouth
NH
I kept the original set-up, just had to adjust the length of the arm(?). It will have very little use so should be fine and if it breaks, I dont need it at a dead stop.
Alaskan Postal nutjob
FORUM MANAGER
Do you have a way to test the motor mount before you go much further? I had the same concern about dealing with the torque and would hate to see it come up way down the line.
timo439
Portsmouth
NH
Same concerns. I had some discussions with a few folks who assured me it’s all good, but as soon as I have powered, I plan to go through some basic tests with the wheels chocked and the e brake on to see if I get any movement. One thing I don’t knows is how much I should torque the band closed. For now, it’s on the one grunt scale with my breaker bar.
Silver Member
This makes no sense to me...
Someone please tell me this is shown installed upside-down and on the wrong side of the firewall....
I was only holding it there to show the bolt hole discrepancy. It mounts on the other side of the firewall. The pedal pivots run through the large round hole, the 2 holes mount to the master cylinder and brace it from the pedal assembly.
RockTractor
Albuquerque
NM
Whew!
