Gladiator - Take 3
It sounds to me like you have an issue with the CAN bus somewhere in the engine or cabin harness. The intermittent ones are the worst, because how do you find it? It's a slow process of checking the A to A and B to B terminals/wires between all the modules on the main CAN bus and the STAR connector (basically the CAN hub). You actually have a few CAN buses, but your issues is probably on CAN C, the main bus. None of the other buses would carry run-critical information.
I'd start by doing a close inspection to any wires near any of the body or chassis work you've done. It can be easy to pinch a wire or two and not realize it, and modern wires are getting pretty flimsy, because they generally don't carry much current, so they don't need to be a very substantial gage anymore.
I've attached a schematic that shows the pin numbers at each module for CAN C +/- and lists an junction numbers in between
If there's something more specific that you want, I can try to get it. I think my YJ probably has less wiring in it than just the PCM on these new Jeeps.
I appreciate this! Also to add after the 1st set of 2 issues last week I replaced the green bus bar behind the glovebox with a MOPAR new one. NO change with my issues. I shared this with the dealer and they checked it along with the wires in that vicinity and found no issues. Looks like I have some work to do when I get it back if they don't find anything.
Hopefully it is just a nicked wire, but could be a PIA to find.
I had a similar issue with my new 2026 Ram 2500, my fault. I installed the factory installed power side steps. Part of the install entailed removing two tiny wires/pins from a harness connector and installing two new wires. This connector was buried under/over the steering column and pedals, major PIA. I made a note on the instructions that I very slightly damaged the insulation over another wire while de-pinning the connector. I mean slight. BUT, these wires all so very tiny/cheap/flimsy.
Long story short, about two weeks later, my truck started having major electrical malfunctions. It would start, run and drive fine, BUT nothing else would work. No touch screen, no dash, no AC, no PW/PL, no power mirrors, nothing electrical would work. Took it to the dealer, I showed the tech what I thought might be causing the issue from my install notes, yep, that was it. The tech plugged it into their diagnostic computer and it told him the fault was within that harness. They installed a new connector/repair harness, no issues since.
I noticed back in 2005, on my new TJ, how small the wires were compared to my old CJ's. Well, they have gotten substantially smaller and crappier since then.
This is one of the reasons I will no longer keep a new vehicle after the warranty period is up, or modify said new vehicle, . Too many small wires everywhere, major PIA to diagnose and repair problems. The newer vehicles have so many features and safety things that are really nice, as long as they are working.
Ozark Overland Adventures on youtube had an AMW swap done on his gladiator. During the process they had electrical issue, that i cannot recall specifics, but it required depinning and changing the plug out for another. This was on harness not touched by AMW for the swap if i remember right. If you can find his video and fast forward to that section it may or may not be related to what your seeing if they can't fix it.
I type this as I sit at the dealership…..
Drove down to pick it up today since my wife had to be down here anyway. Tech and service advisor agreed might as well go ahead and get it.
They did not charge me a dime since they never found anything. That was very nice of them. I thanked them and hopped in.
IT BROKE DOWN WITHIN SIGHT OF THE DEALERSHIP!!!!!!!
I was able to coast into the next parking lot and after cycling the key was able to limp it back. They made a phone call to someone who suggested checking the main TCM connnector behind the passenger front fender well. They wiggled it and the Jeep was good again.
They took the connector apart and it was full of corrosion. They are currently cleaning it and testing. The connector isn’t available by itself and they do not have a full harness in stock.
Stay tuned…
Back home without the JT. It broke down a 2nd time. This time I got 8 miles away. My wife came and picked me up. They aren't going to touch it anymore today. Going to have a fresh start at it Monday. Now I need to decide how far I take this. I have an option to dump it at a dealer auction with issues disclosed through my brother-in-law's dealership. I'd strip it down as much a possible first.
New technology sucks - especially out of warranty
I'll bet dollars to donuts that the TCM connector is the culprit. The corrosion has probably traveled up those wires, it doesn't take a big change in resistance to start causing issues. And the weird part about CAN is that it will be intermittent like that when there is a slight wiring issue. A straight ground or voltage supply wire, you can clean up and it will work 99% as well as it did before. However on comm lines, at lower bus loads it will be more or less okay. It will skip message receipts here and there but not enough to fail. At higher loads it will skip more frequently and you can end up with loss of comm and loss of parity failures.
Hopefully they can find you a harness. If you're feeling handy, you could try to replace just those CAN wires and butt splice them further up the harness, the terminals should readily be available from Mouser or some other supplier.
22124472200040 I believe this is the correct terminal, 18-20 gauge wire.
10094733 is the connector shell made by Kostal.
Mouser has them in stock for sure, and also has the de-pin tool. I'm sure other places would have them too though.
68305267AA is the part number for the Mopar "repair kit". It sounds like from the description it's the TCM connector fully populated with about 8 inches of wire. Not for sure finding any pictures of it. Seems to be about 500 bucks at the dealer. Jeg's says they "have it", for 176... still no photos and the description is pretty lacking. It should be in stock around the country, at the very least available for order at a dealer. The dealer is probably looking for the complete harness. Their SOP generally calls for complete component replacement, no wire splicing.
Good luck, I hope you can get it sorted out.
Wow, that's got to be frustrating! Hopefully they can find something conclusive, and you can get your confidence in it back. Imagine if you were deep in the woods, off-grid and this was happening...
Update. They say they found the culprit wires and fixed them. I asked that they put some miles on it, even taking it down the interstate. I asked for multiple start / stops, etc. As of 4PM today they have put 50 miles on it without issue. Said they’d do another 25 in the morning and then call me to pick it up.
Picked up the Gladiator and drove it home wondering if it would make it. Got home without issue. Drove it a couple more times and couldn’t get the thought out of my mind “what if they didn’t find all the corrosion?” Even the tech basically said the same thing when I picked it up.
Yesterday morning it dismantled it. Today it’s gone. They gave it a clean bill of health so my conscious is clean. Traded it in at a closer dealer today. 2027 Ram Rebel HEMI.
This thread is done.
Ah yes, the HEMI Ram, hard to turn down. 8-)
Too bad on the Gladiator, but hopefully it be better for the next owner. I know it's hard to have any peace of mind after what you went through with it.
So, third and final time for this platform?
Should be getting close to seeing an updated Wrangler/Gladiator model.
Yea I don't see myself getting back into a Gladiator anytime in the future. While I love the connection to our beloved Scramblers at the end of the day a Wrangler is a better platform in the modern world.
