God Nooooooooooooooooo!
It's only 16-17 hours from Cincy. Of course, I am 5 miles closer to Arkansas than you. (Westwood).:D
Now Kevin!
Now just a minute. It is only 670 miles & 10.5 hours from here to Hot Springs, and 35 minutes to your house from mine. We don't count break downs in Louisville and getting "Misplaced in Memphis".:eek: :D :crazy: LOL
Er, ahh, yeah, I guess you are right. But, I don't plan on peeing out the window to save a pit stop.:thumbsup:
update
Planning on scanning the ECU tonight and addressing the CEL. I'll pull the calipers and hope to find a parts store with some in stock. I'll mount the seats and maybe the hood. I also have to double check the hydroboost unit. After speaking to a pro I found out that my new unit may be bad.
I don't know much about the hydro-boost system, but if there is anything I can do to help give me a call.
I'm a little late on this but I can relate to your experience.
My frame was twisted up in an accident and I had to rebuild the whole jeep as well. It's funny because I called mine the Phoenix as well.
To quote the six million dollar man:
Gentlemen, we can rebuild him. We have the technology. We have the capability to build the world's first bionic man. Better than he was before. Better, stronger, faster.
Thanks Van. After replacing the Calipers and trying to bleed the brakes by myself. I think everything is going to be ok. The hydroboost is not making any weird noises, and after speaking with VAN, appears to be functioning properly. This week I will get her back on all fours, throw in the seats, address a few wiring issues, call my insurance agent, and test drive!
edit: Van was the pro I spoke to and I think we misunderstood each other. Van has been a great help in getting my braking issues in order.
update
Got a lot done last night. RE-bled the brakes one more time before doing some testing. We started out with the Jeep on jack stands and put it through a few different tests. Braking in 2hi,4hi, and 4low. The motor over powers the brakes when in gear and the clutch disengaged unless you stomp on the brakes which kills the engine. We then put the wheels on it and pushed it back and forth stopping with the brakes while the engine is off. We then hooked the jeep to a full size truck (I did not use my tow rig, I did not want to chance wrecking two of my vehicles at once). We first had the jeep off and pulled with the truck. It took some effort by the truck but the wheels did roll which kind of concerns me. This means that it is critical that the jeep remains running. This also means I need to install the parking brake. Finally we started the jeep with it still attached to the truck. I stood outside of the jeep and signaled my buddy to start pulling. I had my hand on the brake pedal depressing 2.5" or so. The jeep did not budge and my buddy was doing a burn out! So it appears and I am confident that the Jeep will stop under it's own power.
Next we addressed some wiring issues. I pulled 40 pins from the LS1 ecu harness to clean that up a bit. We went through the dash wiring and now all gauges work properly and are hooked up to the dimmer for lighting.
Now I just need to throw the dash back on and a seat in it and take it down to the shop to weld in the shock hoops and sliders. I also need to find a tubing bender to borrow so I can build tube fenders and add to my cage.
I also noticed that my passenger side rear axle shaft is bent at the wms. I have a spare that I need to get a bearing and seal thown on to replace it with. I also need to throw the spare shafts on a lathe so the rotors fit properly. This should not affect around town driving but I will not drive it at highway speeds. Or at least I'll try not to!
I'll be calling the insurance agent today!
Looks good man! I am going to be down your way this weekend, maybe we can meet up on Sunday or something. Give me a call and let me know what you have going on!
You forgot to post the picture of the truck peeling out, smoke coming of the tires while the Jeep just stood there! Think of the vendors!
update
I was too busy with weddings over the weekend so I did not get anything done. However, last night I was able to finish wiring the taurus fan and discovered that I need a maxi-fuse for it. Cleaned up the wiring harness. Put the dash and windshield back in place. Put the driver seat in. Drumroll please.....................and drove it!!!!!!!!! ..............................About 2 feet and then turned it off. I left a message for my insurance guy to call me and we played phone tag, so I never really spoke to him about it. This weeks plans are to get it tuned and get it down to the shop for some welding time.
:D Congradulations!!!!!!! Nice Work. We may be heading out to Haspen Acres this weekend. Ready for a test ride?:eek: :thumbsup:
Its going to see quite a bit of street time before I hit the trails. Plus there is too much beer and oil in the soil out at Haspen.
