Thank you very much for all of this. Very helpful. And explains why the turn indicators in the dash light up when one light has an issue.
Sorry, I forgot to mention that as well.What did I learn today? That the crown maker light was wired backward.
After I figured it out, I was rebering reading about it as well. So it did not surprise me. So is it i tentional or just crappy quality control?
This is killing me. Ugh. I need it to go wheeling soon.What a bummer. Hang in there!
I would initially think transfer case too, although I’m worried that the revs are so high for not much speed. Grinding into park? That would seem to indicate that the transfer case is somewhat free spinning even when you’re stopped. Check t/c fluid for metal? Check operation in 4low?I put it in drive and looked under the Jeep and the driveshaft is not turning. And when I shift it i to park, I get a grinding noise. So, I am definitely thinking transfer case
Didn't do anything to it this time while the engine work was done correct ? Just took it out and reinstalled ? ( t case )
That makes sense. Let’s hope that’s all it was- rear drive not fully engaged.Correct. But I had to rebend the sticks since the t-case sat back farther. I think that was the issue. The stick probably bumped the edge of the hole in the tunnel cover.
So I just heated and bent the sticks back toward the seats more to give them more clearance from the edge. Once they cool down, I will put the cover back on and see how things go. Before, the sticks were almost touching the front edge of the hole when engaged in high.
You need to push the TV cable all the way in and then go full throttle. Did you already do that once? Also be sure that the locking mechanism is lubricated and moves freely. After too much mud and dust, the button got gummed up and wouldn’t catch when I tried to adjust it the next time.Took it for a little test run at lunch today. Not far. It did not pop out of high gear. But I am not convinced everything is right again. Maybe it is me being overly cautious, but it does not seem to shift the transmission soon enough or at all. I only got it up to 25-30mph, but the revs were really high and did not shift yet. Maybe the TV cable needs adjusting again. Not sure. But I am not confident taking it anywhere yet
I did it once last week. And it is a new cable so should not be dirty yet. And it moves freely. Again, not sure if that is my issue, but I will try it again.You need to push the TV cable all the way in and then go full throttle. Did you already do that once? Also be sure that the locking mechanism is lubricated and moves freely. After too much mud and dust, the button got gummed up and wouldn’t catch when I tried to adjust it the next time.
