Hmmm...
John N
Addicted....Ex-SOA VP
Rockville
VA
This may tick off my wife....
I got this a month or 2 ago...
This was delivered an hour ago, any one want some pieces off of this....
It's an '85. 360 that I don't need. Any one know what tranfer case should be in it? It says Select Track and has a lever on the driver's side trans tunnel for high/low range, and a slide switch at the bottom of the dash, to the right of the steering column.
Should be a 229 but I'm not positive, I don't keep up with the driver's side pumpkin FSJ's. I guess this is what you need the rollers for, once the body is stripped off.
I might be able to use the under dash switch, what color is it and the interior?
It's camel/tan color. Do you have a 208 you don't want? I don't know a thing about a 229.
Can the wiper delay box and switch swap over to a CJ - I can't rememer if it's the same. If so, I'd be interested in that little nugget.
I have no idea, but the knobs look the same as CJ knobs.
Great, put me down for it.
Sorry, no 208's, the one from behind the T177 is gone (still have the T177). If you are going to run the 727 automaticc why not go with a flipped Dana 300?Or better yet, TF999 with flipped 300? That way you have the lower first gear (will help with the oil burner six) and will be the sme basic parts as your Scrambler.
I forgot to mention that I have a chebby 208. I don't know if they are the same bolt pattern. As a matter of fact, I should have a whole drive train. 6.2L/TH400/NP208.
Truck
Truck
Same bolt pattern but less desirable as both Chebby and Dodge 208's had slip yokes. The Jeep 208 did not.
Hey that front driveshaft is a double cardin - great start for a rear CJ shaft
amcjeepman said:
Hey John,
You can store those at my house, the wife would never notice them among the others.:D
JB
Thanks James...
Welcome over to this site, good group here.
I wish you were closer to help me with this one, I don't even know what I'm going to do yet.
And yes, my wife was a bit "distressed" when she saw the new addition.
bigwalton said:
What rear axle does it have?
Which one?:D
The tug has a really wide Dana 70 with 4.88s and a GuvLock.
Oh the Waggy.....it has a 20 in the rear.
bigwalton said:
What would it take to get the shafts from the 20?
It would take me not planning to use it. Which, at this point, I do. If I had a Waggy 44 rear, I'd rather go that way...for no big reason though.
Hey John,
Is that a Drivers side drop and are you planning on using it?
I could swap you for a Pass drop if you wanted.
Carl
CBRogers said:
Hey John,
Carl
Hi Carl, It's driver's drop. I'm still not sure how I'm going to proceed. I already have a Chevy passenger drop 44, too. I may got that way with a D300, just not sure yet. Part of this depends on me finding a 208 to use. Still think about how I'm going to do this.
No problem.
We can revisit this later if you end up with spare parts.
What T-case is in that Tug? I thought that there was some mixing between the different ones and that some came with 208's.
I have what looks like a 208 on the back of my Tug Drive line but because of paint I cannot read the name plate.
Carl
Carl
I don't know yet. I haven't done much crawling around under it...it sits a bit low. I've read that they used 208s (locked in low range somehow) and 198s (that only had low range). Even if it's a 208, I don't know if it can be converted to run high and low range....that's a question for Craig.
