If you had to build one just..
One ton
Fredericksburg
Va
For cruizin around at the beach what would you build? Like type of gears, tires and size,lift,winch-no winch,5 speed or auto? This may seem like an odd question but would just like to see what others would say. We go to the beach more then anything else and my Yj just did not do what i thought it would with lockers, 410 gears and MTZ tires i have.( See pic)
My Scrambler cruizes the beach very easily, when I've hauled it down to Hatteras. That's with the 360/TF999 automatic/4.09 gears and 33/12.50-15 BFG M/T tires. I do have a winch, but it's not really for the beach. It goes very easily on the sand, even the soft stuff, no need to engage the lockers or use low range. It doesn't even matter if I put 6 or 7 people in there.
Why doesn't your YJ work on the beach?
What didn't it do for you?:shrug:
Just felt like it would dig in and was hard to get going :shrug: It could just be me :crazy: it was a lot of stock jeeps just going right a long and it just did not do what i was hoping :confused:
I've never bothered to air down my Scrambler for the beach. My Grand Cherokee definitely needs to be aired down.
It looks like it would do great! But I know what you mean- I had a Cherokee that just wanted to dig, and a stock Chev Z71 1500 that went anywhere. A couple of things I noticed...wider wheels (10") give a better footprint, and more flotation. An automatic is easier to drive, but they seem to build up more heat, whereas a manual trans is less forgiving but transfers all the power to the ground without building up heat. Tread design on a tire makes a big difference, some tires just like to dig in. Wheelbase is your friend, as is horsepower. Gearing is a close substitute. Soft sand likes a supple suspension. Axle wrap and wheel hop will bury you quick.
Randy I thank i am going to try to get me a set of wider tires with less treed, to start, The rear has a locker and i though it would help but it dont seem to.
Thanks Curtis
The "square headlights" never help anything:rotfl::rotfl::rotfl::rotfl:
Just messing with you;):thumbsup:
Wider wheels and tires will help floatation. If you have 8" rims, go to 10" rims. An all terrain tread or even a street tread will work great on sand. Stay away from mud tires. I have ran Super Swampers before on beach sand, not the hot setup, especially with a standard transmissions. Talk about having to walk on eggshells when starting off from a standstill:eek::eek:
I am not a big fan either "square headlights" thank i may sell it and the 8 and start all over again, :rotfl:
Mud terrains generally (not always) don't do well in sand. I've seen a lot of purpose-built sand rigs on all terrains in my dunes trips.
We took my wife's bone stock JK on the street tires up to the Silver Lake sand dunes here in MI and once they were aired down that thing was A BEAST. To look at the tires you'd never think it, but they were incredible:
I'm sure the traction control helped some, but there's no way it was all due to the electronics. I was shocked and amazed. :huh:
BTW, you should air down to ~10-13 psi, I looked like a goof in my Scrambler (not that that's anything new :banghead: ) last time by not using a good gauge and not airing down far enough, once I did, it was almost unstoppable.
Beach driving depends a lot on how many other vehicles have been up and down the beach and when it last rained. Rain packs the sand but 1000 vehicles running up and down the beach every day ruts it up badly. I always try to stay in existing tracks, but looks like about half of other drivers seem to insist on making new tracks.
Tires can make a big difference. I had a struggle in the Scrambler with highway tires but no problem with my new BFG AT's. Really don't have to let any air out unless the beach is really rutted. When it's badly rutted I limit my driving because things begin to get very hot.
I've driven my Izusu Trooper on the beach with highway tires (35psi) and did not air down and got around just fine (following a good rain). A couple of days later and I aired down to 18 psi but still got stuck because of all the rutting caused by the other 1000's of vehicles (managed to get out on my own).
From what I've seen Jeeps seem to do better than most vehicles on the beach along with most full sized pickups.
I should say that my sand driving is all on VERY loose dry sand on the dunes, not anything on a packed-down beach "road"
If it's packed, airing down won't do much anything I suppose.
I ran a 2.5l YJ for 7 and 4.0l TJ for 10 years on the Assateage Beach or Hattaras. Both were bone stock 5 speeds. The TJ did get 235 tires on it's last go-round. Nothing but stock-ish street treads ever.
I typically did not air down until/unless I got slippage. No problems staying on top the sand and in motion. The only exception was hitting a patch of "dead" sand that was 50% air. We immediately high centered on the skid plates.
And aired down YJ should have no issues. Just slap'er in 4-high and keep a little momentum up.
And sorry about the headlights ;) My switch to TJ earned it "ROUND I" plates in celebration of return to the more classic look.
what would I build for the beach? I htink it would be a Myer Manx but maybe with a Porche motor rather than the VW and with a decent cage
My CJ5 used to work fine on the beach in Hatteras when I lived in Va 100 years ago. it was a 304 with 4.27 gears, open and with 11x15 Armstrong Tru Tracs...
A tire with a round shoulder and wide footprint works best, but a mud tire on a wide rim will do. Your wheels look like 7-8". I'd go with 10" for sand. And tires like the Cepek Fun Country 2 are great in the sand.
I had a set of Mickey Thompson HPs in 31x13.50 on 10 inch rims for sand use. This was for a Toyota with 22RE. They were the best sand tires I have ever had. The HPs were a street tread like their sportsman car tires. Was at Little Sahara in Oklahoma and any dune we were playing on the buggies would stop to watch us! Had several stop to see what I had because it climbed so well with out paddle tires.
What to build for beach driving?
I'd buld a Jeepster Commando ('66-'71).
V6, TH400 automatic, D20 with 2" lift and a nice set of 31" All Season radial tire. Nothing fancy, just a nice classic Jeep.....Oh wait! I already HAVE THAT :rotfl: :woot:
That YJ looks nice, but really, just for the beach you dont 'need' lift, just space to put the cooler and chairs (and people of course) ;)
A longer WB helps alot when your in the sand
