Ignition stuck
Kim Dawson
Member
Molalla
Or
I have an 83 GM column. It's been sitting for over 2 years and the lock cylinder has corroded (I expect) and the key won't turn anymore. I've been spraying WD40 in it but it still is stuck. Anyone have any tips other than pulling the wheel and getting down to the lock cylinder and replacing it?
Mine locked up like you are describing…ended up being this part broke. Total PITA to change.
It's the right key. I'll try the PB blaster. Used the WD40 one day off and on. Set for a week and tried again. I expect the tumblers are stuck in the wrong place. If the blaster doesn't do it, I'll take it apart. Thanks for all your replies.
Might try moving the tumblers with a pick - or even a different key.
What type of column is it?
The best break-free type product I’ve ever used is Kroil, by Kano Labs. It seems to get into everywhere. The problem with the lock cylinder is that it’s brass and pot metal. Two of the worst things to corrode…
Kroil for me.
Kroil for me.
I use it also. I saw some at a store for sale, I can't believe how expensive it got since I bought some last(probably been 6 years though, I bought a bunch back then)
Go to their web site and buy it directly. They seem to always have some kind of introductory price or special.
