Incentive to get my Scrambler driveable...
Randyzzz
Blown Budget
BENEFACTOR
Redmond
OR
...came in an expensive and unwanted way. I guess I'm sort of crying in my beer here.... I lost a cylinder on my DD Jeepster on the way to work this morning. Limped home on 5 cyls...checked , and, long story short, I need to replace the engine. So, you'll be seeing alot more updates and pics on my build thread. I finally got most all the parts I need, so it's time to get the lead out. Got my front spring hangers built this weekend, probably do the shackle hangers tomorrow night...
Luckily, I'm not without transportation- I brought my 53 Ford out of winter mothballs early- I sure hope it doesn't snow anymore.:rolleyes:
Just needed to vent...:banghead:
That sucks...
I thought that the Ford was a project and not drivable... am I wrong on that or did you build on it and not post pics???? :mad:
Randy,
That really sucks, sorry about the bad luck. I hope the replacement goes smoothly and quickly.
Jeff
bigwalton said:
That sucks...
The 53 is a project, but luckily it runs and drives great. I just want to "upgrade":D It has a healthy 350, a powerglide, and a 12v wiring system. Good enough for now. Built 350, nitrous, 700R4, posi, killer stereo...:D
The Jeepster will get a 350...eventually. I'm sick of the V6...it only got 12-15 mpg, if I babied it. But first, the Scrambler gets finished. Then the Waggy, then I'll work on the Jeepster. Probably Fall, if I'm estimating correctly. I want the Scrambler done by Summer!
Is the 350 in the Ford built to where it's not suited to swap into the Commando?
With your situation/plans, that seems like the natural course of things and gives you the "excuse" to upgrade the Ford :thumbsup:
The 350 in the Ford is going to be the basis for the Hi-Po motor I described. It's got good "genes", so I'm keeping it together. The 350 that came out of my Scrambler will probably end up in the Jeepster... I'll give it a quick once through, put on my spare set of '87 heads, and run a TBI setup. But first, I want to get the Scrambler running. Didn't get anything accomplished tonite- I came down with some bug today, been sleeping since coming home from work. :( Maybe tomorrow...
