Intro and a couple newb ?s
skipdup
San Antonio
TX
I may be jumping the gun, since I don't actually have possession of the truck yet. But, thought I should introduce myself. My name is Skip and I live in San Antonio, TX. My father never drives his 8 so he's decided to give to me (I honestly attempted to buy, but he'd have none of it). :) We're still trying to find a way to get the truck from FL to S. TX. And, I'll post pics asap.
I don't really have many details, but I think it is a stock (except seats, center console, etc) '83 with a straight 6 and 4-speed. It was restored prior to my fathers purchasing, but I'm not sure if it was a true frame-off or not. When I last saw it several years ago it was in seemingly excellent/perfect shape. Since purchased it has been covered and driven every week or two for preventative maintenance.
The first mod will definitely be adding a/c. Then maybe lift and 33" tires, vanco hydro-boost, and if needed, making steering factory tight (or better - I'm anal about sloppy steering).
I've tried searching, but haven't been able to find clear answers... Did Jeep use a boxed frame for the CJ-8? What axles do I have? Any info a newb needs to know regarding 8s, CJs or Jeeps in general? Are there certain items which every 8 needs addressed?
Thanks!!
Skip
Welcome Skip
Glad to have you here, you'll get plenty of help with you questions.
Yes the CJ 8 is a boxed frame
dana 30 up front/ amc 20 rear
There should be lots of info concerning steering issues here too. Try a search under "steering box" or "tie rods"
I'm sure more of the gang will be jumping in to help you.
phil
Thanks Phil!
I forgot to ask... What transfer case did Jeep use in '83? And, there were several 4 speeds used, right?
Thanks again,
Skip
skipdup said:
Thanks Phil!
Thanks again,
Skip
No problem, here's what i know...
dana 300 is the TC
SR 4 in 1981, although mine is a 82 and i had one
T 4 or T 176 mostly for the trannies, i'm sure there were more.
Welcome...
Vanco's Hydro-boost is an excellent system, but considerable overkill with 33" tires. If you go over 35" tires, then maybe. His duel diaphram system will do all you want and he has it on special right now for $375 (I think).
Welcome to the SOA. The t-case is a dana 300. Good case, no need to ever worry about it. There is possibly 3 different 4 spd's it could be. If the trans shifter comes out of the floor forward of the transfercase shifter it is a t-176. Great trans. If it coimes out of the floor at or behind the t-case shifter it is either a t4 or sr4. If you have to push down and toward the driver it is a sr4. If it is a t4 it will go over to the right and back for reverse. The t4 is a ok trans but the sr4 has some potential problems. Congrats on your new ride!
John N said:
Welcome...
I agree with John. The Vanco also has a few complications to consider, like possibly a new power steering pump and new lines. So, like John says, unless you are going to change to really big tires, then I would check to see if you have a booster behind the master cylinder. If so, you should be fine. If not I recommend something like this new power booster pictured below. It is available on ebay for $220 shipped. Item number: 8064885370. Here's the picture from that auction.
BTW, WELCOME to our Scrambler Family!!!
Welcome to the expens.... I mean wonderful world of Scramblers..;)
I have an 83 and you probably have a T-5 5 speed and definitely a D300 Transfer case.
You must have been lurking here as you noted the need for pics in your post. Good Job. Big Walton will be proud of you!
Keep us posted. I know there are seveal '8 owners that post here regularly and there are a bunch just up I-10 in Houston.
Thanks everyone!
TexasAg77 said:
... you probably have a T-5 5 speed ...
IIRC, from when I drove it several years ago, it has a 4 speed. That may be added to the list of to-do's.
TexasAg77 said:
... You must have been lurking here as you noted the need for pics in your post. Good Job. Big Walton will be proud of you!...
Too funny. That's exactly why I said that. :)
- Skip
Welcome Skip and if i can help don't hesitate to PM me.....................You will find this board more of a family than an internet site..............;) And i'm not near as bad as everyone tells you that i am.................just cause i hacked up a scrambler for a trail rig they seem to think i want to chop everything up...................................can't understand it..........:confused:
Ah, my work here is done :D
[EDIT]Removed comments about manual trannys because I'm apparently a dumbarse and should know better than to comment on them[/EDIT]
Good luck getting the rig back to you. Is it running? You've got a good bit of help between FL and TX if something goes wrong if you try to drive it. Long treks in Scramblers are FUN!!! :cool:
bigwalton said:
.... Is it running? You've got a good bit of help between FL and TX if something goes wrong if you try to drive it. ...
Yes, it runs. But, my father is convinced I have inherited his "luck"... therefore, I'll never make it to TX in the 8.
It will be easier to either drive down and tow it back, wait until he can tow it here or have it transported than it would be to change his mind. :)
Time goes slowly...
- Skip
bigwalton said:
You don't want a T-5, it's a notoriously weak tranny. The T-4 is better and, although 3-speed, the T-176 is generally considered the best stock manual.
:confused:
I have been under the impression that the T-4 and T-5 were basically the same transmission with only difference being the T-5 having the overdrive 5th gear.
And the T-176 is a 4 speed transmission. The T-150 was the last 3 speed manual transmission to be used in a Jeep and was discontinued after 1979.
It's probable that an 83 would have the T-4 transmission.
Boomer said:
:confused:
I had the same impressons on the T-4/5 deal. The 5 speed was put on for fuel economy. Otherwise the same. I have been told the same thing about tearing mine up with just the 4.0, but so far it is holding together. Now put an LT1 in and I bet it wouldn't last long!
Drive it. You know you want to.
Even if you get halfway, you can rent a trailer and a U-haul and get it back for less than shipping it out...
Besides, it's a MUCH cooler story to start your ownership of the -8 :D
I'm with BigWalton on this...
DRIVE IT!!! :D :cool:
I picked mine up in Flagstaff AZ and drove it back to Virginia Beach VA. It was a blast!! :D Take the top off and enjoy all that Florida sunshine.
And welcome to the 'club' !
scrangler said:
... There is possibly 3 different 4 spd's it could be. If the trans shifter comes out of the floor forward of the transfercase shifter it is a t-176. Great trans. If it coimes out of the floor at or behind the t-case shifter it is either a t4 or sr4. If you have to push down and toward the driver it is a sr4. If it is a t4 it will go over to the right and back for reverse. The t4 is a ok trans but the sr4 has some potential problems. Congrats on your new ride!
I talked to my father today... he said the trans shifter sits maybe a couple inches forward (towards the engine) of the transfer case shifter. (The shifter boots overlap each other - if that's important)
Reverse is passenger side and down.
So, does this sound like the t-176?
Unfortunately, it looks like it will still be a couple weeks before I'll be able to get the Jeep.
Thanks,
Skip
