Jeeps, Trades, Camaradarie... and a padded Grab Bar!
I have reversed my position, 180 degrees!
I fk'd around with conduit all weekend, and couldn't get it to bend the way I wanted it! This project will require an actual tubing bender (with the correct dies), which I do not have... and I'm not going to buy it just to make door pulls.
Jim's Chop Shop has graciously offered to send me a factory door pull to replace my broken one, and I whole-heartedly accept! :thumbsup:
Thank you, Kim Dawson, for offering to leather-wrap my home-made door pulls... but it's just not in the cards for now.
Take it easy! :cheers:
My local library has a laser cutter and cnc mill free to use. The laser says it will cut leather. If this is something Kim makes a pattern, we may be able to cut quick and accurate!!!
Also has an air knife vinyl cutter
That's a pretty awesome local library! We definitely don't have one like it here
That's a whole new meaning for a library. Thumbs up for Kansas! I make leather parts for cars in the early 1900s out of harness leather. Some of them I have a die made that is like a knife the shape of the part. I put the die in my press on top of the leather and work the hydraulic jack until it punches out the part. A production shop that cuts out lots of parts will have a clicker machine. The clicker has a large bed and the upper plate comes down under power like a power brake and . . . click . . . your part is stamped out. For now, I'm using scissors. I've sent off for some samples of leather and am trying to locate some original materials to match before I order leather in the different colors. BrooklynZ28 is sending me a slate blue grab bar for reference. I took apart my nutmeg grab bar. I don't have any honey or garnet parts to match so if someone has a torn up seat they can cut a spot with accurate color and send it that would help. If that doesn't happen, I have Napa making up those colors and I'll match the paint.
Kim SEM dye in "Camel" is a perfect match for Honey.
The dashpad is original and on an all original, always covered 85 Scrambler (no fade at all).
The grab bar was originally Honey, but had faded to a greenish hue. I sprayed it with SEM.
SEM is available online or at Sherwin Williams auto paint places. You could either spray the leather with SEM, or use it for color matching purposes.
Yeah, I need to take advantage. One of the monster engineering firms (black and Veatch) sponsored the "makers lab" for the library, but it does seem like a really cool item to make a library even more useful!!!!
Ordered the SEM Camel from the local Auto Zone. Checked out Napa and O'Reillys which didn't carry it, but Auto Zone can have it in a day. Napa mixed up my Slate Blue and Garnet colors, but they are still trying to find the formulas for Nutmeg and Honey. Color codes are older than most of the people working there.
Wow. Just Wow. I think our library has pencils, rulers, and a magnifying glass. If we had that stuff at our library I'd be spending a lot of time there...
Our Scrambler has a top that was listed as "Honey" on the original build sheet, but it's darker than the interior. I painted my hardtop with the SEM and it was quite a bit lighter than the original Honey hardtop exterior. Perfect match on the interior though.
I didn't realize NAPA could pull original interior colors and mix to match. Is it dye or paint or ??? If you can pull off a good match to Nutmeg you'd have a gold mine on your hands.
Napa's paint chip books show both interior and exterior colors, but not the mixing formulas. They go to the computer to search for mixing info for their CrossFire Acrylic Enamel paint. I was wanting the enamel to paint the metal of the grab bars. Honey shows up as an interior color in 1984, and a Dark Honey for the exterior. Nutmeg only shows up as interior color. Napa used exterior formulas for Slate Blue and Garnet. If I have to, I'll shine up my nutmeg grab bar and have them match that. Is the paint on the honey grab bar a match to the leather color?
Yep. The one I pictured I sprayed the whole bar, leather and metal, with the SEM.
I have Honey grab bars on all three of my Jeeps (all are 85's with Honey interiors). Two are sprayed, one is original. Can't tell the difference in any of them.
Interesting that Honey shows up in 84. It was 85-86 only on CJ's, but might have been used in XJ's or FSJ's in 84
Picked up the SEM paint today. Sprayed some to see the color. Quite different than the butterscotch looking cap. For the Nutmeg, there was a color chip very close to my grab bar but a little darker. A little less black, and a little more yellow, and the color is as good as I'm going to find for nutmeg. When the blue grab bar arrives, I should have all the colors to match the leathers to. Thank you all for your help.
Yep. I first tried the SEM back in the 90's. I've painted door panels, visors, grab bars, and a Tuffy console (and cushion) with it. Even a hardtop. It won't stick to the door pulls, which are rubber. You are correct about the actual color not matching the cap very well.
So on the nutmeg, is what you're getting a dye or more of a paint like the SEM?
A LOT of people are looking for nutmeg stuff in the Jeep community.
The nutmeg I had mixed is acrylic enamel to use on the metal grab bars. I've got samples coming for leather. One of my leather suppliers has leather that matches the honey color (SEM camel). They have a line that shows both leather and vinyl of each color. Not always a perfect match but very close. Should you need leather or vinyl for your honey interiors, I can give you the particulars.
After seeing Jerseyjeeps low mileage garnet interior in pictures (looks very bright), and other garnet interiors parts (looks dark and more maroon), I'm thinking the garnet upholstery could be quite different than the garnet exterior paint. Does anyone have a garnet door handle or piece of upholstery that shows the color to match that they could send?
