Update....
Hi Gang,
The Scrambler is now being driven daily and I'm fixing the "little" problems as they arise. Yesterday I removed and replaced the heater core and did a bit of a "rebuild" on the heater box. Here's what it looked like when I pulled it out:
And here's a shot of it after I cleaned everything up. This is just before I buttoned up the back:
I have a couple of small projects left before I can move to "tinker" mode where I fix the small things:
1. Rebuild the power steering gearbox. Anyone here done this before?
2. Replace the clutch disk, TO bearing, and pilot bearing (clutch chatters badly)
The only irritation I'm having right now is getting the BBD to idle correctly. It runs wonderfully, but when I transition from highway speeds to a stop; it wants to die. Once I'm stopped and I feather the gas, it will hold idle just fine. It seems to want to die after extended high speed runs.
I'll post more as things progress. I have about 250 miles on the Scrambler and I'm very happy with how it is running (other than the idle problem).
Joe
