- Ducor
- Ca
Those look amazing!!
X 100Those look amazing!!
I’ve been working on getting the universal harness modified to my needs and finally today I felt I had it. I’m hoping I didn’t forget anything- I already had to add a power feed to keep the GPS speedo awake, and run a wire for the MIL indicator. Also, instead of making one large bundle with a lot of branches, I created individual branches for each major group. Might look a bit more cluttered, but if I ever have to troubleshoot I’ll be happy. Here’s some pics-
I’ll get you a measurement tomorrow.I've never replaced any of mine and I have a couple of split stock ones. What thickness are those ?
For 3/16”, I think my solution would work best. If I had discovered it before paint, I might have hon that direction. But- it’s off the same side to side so there’s no twist. I’ve got a body mount that’s off almost that much! So, it’s level and simple height adjustment via my overthought shimming will work.Randy
If the frame rails are warped, could you put on a frame machine and pull it back to spec ?
That’s a great idea. There aren’t many boat supply places around here, and the ones there are don’t have squat. I already ordered that $75 chunk. Seems I can’t get away with anything inexpensive on this build!On my son’s J-10 build, we needed to do a custom body lift. We used boat trailer rollers from West Marine. It seemed like pretty decent polly material available in multiple colors, not cheap, but not too expensive.
FWIW I put my speedo GPS antenna on the back of the Windshield VIN plate and ran the wire through wiper harness holeRivets arrived a few days after the last post. Worth the wait.
View attachment 95908View attachment 95909I’ve been working on getting the universal harness modified to my needs and finally today I felt I had it. I’m hoping I didn’t forget anything- I already had to add a power feed to keep the GPS speedo awake, and run a wire for the MIL indicator. Also, instead of making one large bundle with a lot of branches, I created individual branches for each major group. Might look a bit more cluttered, but if I ever have to troubleshoot I’ll be happy. Here’s some pics-
The bulkhead pass through.
You get a lot of length here- most of these will feed into the under hood power distribution center/relay center.View attachment 95911
The fuse box is in the stock location, just spaced out an inch to allow room for the individual branches to feed out. If you zoom in on the fuse panel- the fuses labeled in red are always hot, the ones in white are hot with key on. I also made some custom labels for stuff like GPS memory and TCC switch…View attachment 95912
Passenger side of the steering column- a bit busy here with all the switches and the big trunk to the gauges/HVAC system.
So, that’s it for now. Waiting on another backup camera, I used the last one on my blue Silverado. I’m also brainstorming on where to put the speedo GPS antenna. Under the cowl vent won’t work because there is a plate covering the opening. I’ve got a couple ideas though.
I’m also still working on the radiator mount. If I just gave in and went with the 1” body lift instead of the 1/2” it would work as is. Might be a wise choice but I really don’t want or need any more height.
I have aftermarket poly stock height mounts. They are 3/4” tall. Just measured.I’ll get you a measurement tomorrow.
I’m thinking somewhat the same. If I drill a small hole to pass the GPS antenna connector through the inside of the windshield frame (not easy but possible) I can mount the antenna pod on a little bracket that will take the place of the windshield strap bracket. Fish the cable through and out by the wiper motor. That’s how I ran the wires for Copper’s switch console. Just wish I’d have drilled the hole before paint. And, I’ve never driven with a folded down windshield. Ever.FWIW I put my speedo GPS antenna on the back of the Windshield VIN plate and ran the wire through wiper harness hole
