- Redmond
- OR
Yep!?Twice pipes ?
Yep!?Twice pipes ?
Man that's great information I really appreciate it. Exactly what I was needing to move forward. Saved me from having a pile of manifolds and scrap pipe.Did a little fit checkIng on the exhaust. While the C6 LS2 manifolds are a great fit, especially if you want to cross over in front of the oil pan, I am really happy with how my LS3 2010-2015 Camaro manifolds worked out. I cut up the crossover pipe I made for the J-20 and used what I could. The passenger side is a great fit. I’ll have to play a bit with the drivers side angle but it all fits. Just a FYI on firewall fit. I try to keep everything frame level or below behind the front body mount outriggers. That way it should all clear without a body lift. Here’s a few pics. Drivers side first.
View attachment 78698View attachment 78699View attachment 78700On to the passenger side. The engine is sitting in the far left position so clearance is much less here. The manifold dumps slightly over the frame. A quick bend cleared that, now I just have to work out the angles for max clearance between the hot pipe and the trans pan and frame mounted lines. I will most likely add a welded on heat shield, along with providing heat shielding for the brake lines and prop valve. I’ll run the fuel lines up the trans like I did on Copper.
View attachment 78701View attachment 78702View attachment 78703From there I’ll run a H-pipe crossover behind the transfer case, turbo mufflers, and duals our the back corners. Should sound great.
The truck manifolds seem to flare out too far at the back. The Camaro manifolds are about perfect for a rear dump Manifold.Man that's great information I really appreciate it. Exactly what I was needing to move forward. Saved me from having a pile of manifolds and scrap pipe.
Having to install them separately, yes. Fortunately the harness is plenty long if it's out of a truck. I was a little glad to have them in the C6 already - makes for easy access to them as well.Only down side I can see is the need for O2 bungs in the exhaust pipe instead of built into the manifold like the C6 is.
Did I miss this being right hand drive?
Isn’t the left side the driver’s side?
Looks great though, wish I had the stamina to build that quick.
I ended up giving these headers a try. They seem to clear Dave's motor mounts very well. I'm going to mock up the engine w/bellhousing this weekend to see how it interacts with the frame and steering.The truck manifolds seem to flare out too far at the back. The Camaro manifolds are about perfect for a rear dump Manifold.
Those look like they will work great. They dump close to where the C6 manifolds do.I ended up giving these headers a try. They seem to clear Dave's motor mounts very well. I'm going to mock up the engine w/bellhousing this weekend to see how it interacts with the frame and steering.
Thanks for that info! Much appreciated. Taking day off tomorrow to start the fit up of engine. Couldn't wait for weekend!A little heads up- if you’re looking for 2 1/2” exhaust band clamps, look on Amazon for these beauties. These are the same ones that Ford uses and charges $30 a piece for. These are sold by Hooker and cost under $22 for two! The actual brand is Torca, and they have an inner sleeve that seals great, unlike a lot of the thin overseas stuff. View attachment 78815
First mock up in progress.Those look like they will work great. They dump close to where the C6 manifolds do.
That’ll work!First mock up in progress.
https://www.thenccmotorsports.com/So... working on the exhaust got me thinking about side exit vs rear exit. That got me thinking about fuel tanks. I want at least 20 gallons. The tank I used in Copper was perfect- a fabricated 20gal steel tank. But they are no longer available. I prefer a steel tank because I’m installing a GM factory fuel module. I could install the GM module in a MTS or Crown plastic tank, but I don’t know if either have a suitable flat top to cut out and install the flange. They hang pretty low too. The 33 gal Aero tank is a beast and with 31” tires it hangs even lower. And with shipping and options is $1100. Same with the Gen-right tank, $1200 for a 20 gal tank. Ouch. Always looking for another option, I’m considering the 25 gallon 91 Blazer tank. It’s 9 3/4” deep and fits between the frame easily. One crossmember would have to be removed and relocated or a suitable replacement installed. I might have to clearance the cross-bed brace that the body mounts sit on, but that would be easy. Getting a new tank would allow me to weld in the proper fill neck, and modify the module mount as/if needed. Or just use the 91 setup with a Walbro EFI pump. Best of all a new Blazer tank is about $100. Any thoughts?
These guys are making me a new fuel tank and cage. Since he has my frame on hand he may be able to make something for you. I'm running parallel external pumps but, he may be able to do something internal. Said he can get me between 20-25 gallons no problem.
