This AMC 360 motor makes good oil pressure hot and cold ....and I know it would be hard to stop myself with just a HEI dizzy swap.
Been hard enough not to break out the compound & polishing to the paint. Jeep has no rust
Motor has plenty of power and would white smoke the old tires easy.
Was mostly just wanting to get rid of old ignition and move MSP inside away from muddy water.
Set the rev limiter to 5800.
Buddy of mine thinks he's got ignition & tach wiring figured out, which will use heavy red with white tracer so the tach plugs in like stock.
The battery is just on other side of firewall and the heavy ground on MSD is just long enough to reach.
Painless add on fuse block will fit on left or right side of factory fuse block.
Would be easier to mount & access on right... but the brake pedal is only 1/4" away.
Plus would be hard to keep wires out of that movement area.
Just not enough room beside pedal & column mount for wires to exit to top.
This Scrambler was manual, I swapped in auto brake pedal and repurposed the A/C firewall plate to cover the hole for clutch rod.
Need to find an A/C boot for lines to pass thru.
Anyone install A/C, what did you use for high & low pressure lines thru firewall?
Left side is better and there is a factory knockout thru firewall for additional wires right above.
Gotta take out the emergency brake to install... easy enough.
Now...Going to concentrate on getting rear winch mounted & new heater core.
