- Baton Rouge
- La
Jeez Dennis what happened
That was last year on one of my first drives.Jeez Dennis what happened
Someone has been too busy training his goats and not paying attention.![]()
Your helper is certainly dressed appropriately... will she be driving this Scrambler in a few years?
Due to the limited seasonal expected use of the Scrambler, I am thinking of an onboard battery maintainer.
I've been gradually switching from Optima to Odyssey AGM batteries.
I read not to charge AMG with traditional charger.
Don't really need high amp charger like this one, but all I can find for onboard AMG charger:
Any suggestions or thoughts?
http://www.ebay.com/itm/351230314734?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Got steering column installed and wired it up ......... Houston we have problem.
When turn key I only have power to volt meter, nothing besides headlights work.
So I assume that this contraption that works with key is problem.
I have the key moving the rod and the 90 degree end of rod stuck in slot & mounted to column
Am I missing something on this?
First CJ that I've ever had with this rod / key gizmo.
Any tricks or tips on installing ?
See my response (post #6) to a similar issue:
https://www.cj-8.com/forum/showthread.php?46752-Scrambler-ignition-problems&highlight=ignition+switch+adjustment
It covers installation and adjustment of the switch/rod.
Pics are dead on that link. Would you post pics here?
Is there a bushing or does the actuator rod just stick in slot?
Any tips on adjusting the fore / aft of the gizmo?
