My Scrambler Substitute
WOW! The Commando with the CJ clip looks sweet!. Now I want a scrambler and a modded commando like that one.
October 08 Update
Slowly but surely Goose is nearing completion. We got it together enough to make the September trail ride at Oak Ridge. Lots of little things were missing like doors, roll bar, most of the wiring, brake lights, instruments, etc. Jersey Joe came down from New Jersey to ride shotgun on the maiden ride. He was white nuckled a few times on the slopes with no roll bar protection but we had a great time and Goose was awesome. Here are a couple of pictures from the ride:
Since then we have been working on finishing the rig with the missing roll bar taking high priority. To get the height and look right I put my half cab:
The roll bars that came stock in the Commandos are small diameter like the the CJ's had not the big boys like a Scrambler. I really like the beef of the 3" Scrambler roll bars and upon careful study determined that a Scrambler bar just might work on Goose.
to be continued...
What kind of half top is that? Looks GREAT! Never seen one like that before (not that I've seen a lot of commandos).
What kind of cage are you looking to end up with?
Just my two cents, but I'd pass on the Scrambler roll bar unless you recreate one from new tube. There's a thread on here about the (lack of) quality in the stock Scrambler bar and if I were you with a blank slate like that I would do something custom that you knew would hold up.
Scrambler sacrilege!
The Commando body demensions are very close to a Scrambler in many ways and after test fitting Nick's (Ted's son) Scrambler roll bar in the back of Goose one day I decided we could make it work (that is, Ted could make it work. He the welding magician!). I recently picked up Wild Turkey's Line-Xed stock roll bar and swapped it into my Scrambler (my bed and interior are Line-Xed) so I had a "spare" Scrambler bar.
In stock form the legs are too long and we determined it would look and work better if it was turned around so Ted cut the legs off. The front legs will sit on the front of the wheel well so we had to shorten them to work:
Here is a shot of the main hoop in the bed, it fits like a glove! The roll bar has only 1/4" between it and the sides of the Commando.
to be continued...
The stock leg length is too long for the Commando bed unless they connect to the the top of the bar. Here is a shot of a test fit:
We did not like the look and decided to shorten them and put the back where they are on a Scrambler. Because of the sloping sides of a Commando and the large mounting plates we had to angle the rear legs slightly toward the inside of the Jeep or we would not have been able to get it out again.
Here's a picture of Ted checking out the welds on the completed roll bar:
And a couple pictures at different angles showing the finished product:
I ground the old welds off the now front of the bar and took it home from Ted's to prime it before dropping at the Line-X place. I should have it back by next week and can get it installed. I will post pictures of Goose with the modified Scrambler roll bar as soon as its in.
That's an original Commando metal half cab top. You know, if you study these things you realize all Jeep did to come up with the Scrambler is marry the Commando half cab with a CJ7.
The roll bar we used is from my 81 and is very solid. I don't like front legs on a roll cage because my legs are too long and they get in the way. You can't use a dash mount like John N's Scrambler has because the dash design won't accept it. For my wheeling the Scrambler roll bar will be fine, and I really like the look. Besides, it helps make Goose a one-of-a-kind Jeep!
Gotcha and I certainly understand the leg problem.
I had visions of this thing being towed to Moab to do Hell's Revenge, so I had a sick cage in my mental picture :evil:
Picked up the Line-Xed roll bar at 5PM and hightailed it over to Ted's to get it installed before dark. Here are some pictures of the final product:
It looks fantastic! Can't wait to take some more picture in good light and when Goose isn't under the cover.
I like that look.
It seems to be coming together for you. Also the way you did the tail lights works well too.
Carl
Commando
I ran into a Land Rover shop in GA...he is all about the old school Defenders and other euro 4 wheel drives...
...anyway he has a late 60s Commando frame and other misc part (I think he said it was a 69?).
He will give it all up for free...if anyone is interested PM me and I will find his contact info.
I am on a couple Commando boards and will be glad to post the information if you send it to me.
Wow, looks pretty sweet. Being a hard core Jeep guy I hate to see the 225 and the Commando grill go, but it does look awesome and unique w/the postal grill. (And I can't really complain about the Vortec either......I put a Caddy 472 were a 230 Tornado used to be, a 401 where a 258 was and a 4.0L HO in place a 226! Gotta love Jeeps.....no rules!)
Update,bigger tires = 39 inches,the Dana 300 is getting a JB 4 to 1 low range,and 32 spline output shafts,front and rear.
That looks great...need a whole picture to get the full effect!
CrazySchaefer said:
man thats sweet looking! where did ya get the 39's?
Got a smoking deal on a set of new, never mounted, military 38x11.00x16 Michelin XL's ($500). Ted and I found the 3 of the rims at a junkyard ($65) and I bought the 4th from Summit. Had them mounted and balanced Friday and dropped them by Ted's, where the Commando is right now, with ans to install on Sunday afternoon. I had test mounted one of these tires from off my M715 and it looked like they would work. The XL's are listed as 38" but measure 38.7". At 11.00 they are narrower than the 35's they replace but when aired down they will actually work a little better, giving Goose a little more ground contact pressure. Also, the lugs on these tires are really deep and will bite well when climbing.
These tires are so tall we were worried that they would rub the springs in front but Ted proved I still have about an inch to spare at full lock. Just further confirmation that narrowing a WT FSJ 44 is the way to go for big tires. The rims are 16x8 with 4.5" backspacing and do not rub/hit (could not go with that much back spacing with a 15
rim).
I am going by Ted's this afternoon and will take some more pictures and test drive it. Can't wait to run Oak Ridge with it in March.
