My wife bought me a Jeep!
mattymajors
Spring Creek
NV
#22
Wiring is coming to a close on the 4.0 swap. Today I stole the PCM bracket off my wife’s 95 YJ and tweaked the CJ batt tray to accept it. Worked really well.
mattymajors
Spring Creek
NV
mattymajors
Spring Creek
NV
mattymajors
Spring Creek
NV
#25
In the in between time... finished the drive-over fenders on the trailer. Picked up my wife’s YJ. Got in a quick Moab trip.
Aurora
#27
I like the ss/chrome accents on Little Red. I’m debating if I want to go that way with my Tj to Cj build. Getting those door and windshield hinge bolts off can be a monster. You’ve got a pretty sharp looking Cj8 there.
jak inc
I H8 SALT!
Merton
WI
#29
Winch build looks good! All you need are some Jeep Special Equipment winch directionals.
mattymajors
Spring Creek
NV
#31
So, Santa brought this. I would have put it on before setting the new engine/wiring, but hey it wasn’t too big an issue. Pulled the water pump, labeled and removed all the intake wiring, just put your hands into dark holes and old manifolds will come out. New gasket, double checked flange thickness, and in it went. I did find that I was missing an intake bolt underneath, so that’ll be on the way. I believe it’s a 1.25” 3/8x16 bolt w/ 9/16” head and a goofy washer that the internet sells.
mattymajors
Spring Creek
NV
#34
Pman
Busted Knuckles
Mount Pleasant
SC
#35
Wow! Subbed to this thread. You didn't mess around when you bought this a couple of years ago. I had to laugh just a bit about your 8274. I bought my old Warn from Dawn and Jodie Abbott in Cartersville GA (I think they are members here and awesome folks), and it worked wonderfully until about the time my steering box puked. Here I am chasing the leak on the steering box (which truly was leaking), and then I start noticing oil collecting all over my winch plate. I thought the high pressure side of the steering box was shooting fluid up there, and it turned out the blasted winch started leaking at almost the same time!
Really strong work on your 8. When I get done with mine I'll refocus on my winch and will definitely refer to your pics.
mattymajors
Spring Creek
NV
#37
I got a lot of feedback on the “leaking case” prior to cracking it open. I got great work from a guy in SLC who knows these things inside/out, no leaks pulled the CJ around easy during the engine swap.
