Finished removing the remaining items from the body tub last night:
heater box thing(s)
fuel tank evap stuff (unfortunately, the liquid check valve is rusted out)
rear light harness and harness mould thing in rear fender well
fuel tank fill assembly
and some other small stuff
Picture of the interior side of the firewall, pretty clean and rust free.
Even the driver side fender well underneath the plastic wire mould thing is 100% rust free. The visible rust in the picture is just surface rust.
This is the worst rust on the entire under body. This is the sheet metal box thing at the very rear of the body tub. It looks really bad, but besides the visible hole, it is still solid. I hit it with a hammer repeatedly, it is still good. But, it will be wire wheeled down and repainted when the tub comes off.
Since I have never pulled the computer out of a CJ before, I thought the AMC sticker still being present was pretty cool.
And on the other side of the computer we find the "Blue Oval" - now I know why all these computer controlled carburetors get a bad wrap, damn you FoMoCo
Stripped the front of the engine down, also removed the two manifolds that have just been kind of hanging in place. Motor is about ready to pull.
One of the previous owners removed the cylinder head along time ago. Unfortunately, they did not remove the exhaust from the manifold, and with the head not present, it is about impossible to remove the two solidly rusted manifold to flange bolts. A sawzall will fix this.
Not sure why I took this picture, I guess to show the almost 30 year old oil/mud crud mix???
I also decided to see if I get body mount bolts out, kind of the "moment of truth". There are 13 body mount bolts on a Scrambler, 1 under the grill (already removed) and 6 down each side of the body tub. I will number them 1-6, with one starting at the front of the body tub. Before attempting to remove the bolts, I heated each one with a torch for a few minutes, long enough to catch the rubber mounts on fire !!! To break the bolts free, I only used a short 3/8 drive ratchet.
Passenger Side - 1,2,3,4,5 came out with no problems. Number 6, at the very rear of the body did not come out. It reversed a few threads then broke the welds that hold the captured nut thing. That is no big deal, easy to get to that.
Driver Side - 1,2,3,5 came out with no problems. Number 6 was the same situation as the Passenger Side, so no big deal. Number 4, which is located on the inside of the frame rails right next to the front of where the gas tank would be, is a problem. First twist broke the welds on the captured nut thing, well I am about 90% sure it did. I will cut the head off the bolt to pull the tub, no big deal. And I think I already figured out an easy way to fix the broke captured nut thing using simple hand tools, stay tuned.
That's it for now.
