I got back to work on "Yard Scrambler" this weekend. I was able to clean/prime/paint all of the loose suspension/steering/frame attachment pieces that have been floating around in the yard. None of these parts were rusted too bad, but they were all covered in surface rust, and I could not bring myself to bolt this rusty "junk" on the nice clean frame.
Before shot of all the parts needed to bolt the suspension back to the frame/axles: shackles, shackle hangers, steering box hangers, steering stabilizer bracket, and U-bolt plates. I removed all the new bushings from these parts before I started cleaning them.
Picture of the leaf springs. At first, I was not going to clean them up, but in the end I did. I believe they are some type of lift spring, perhaps a Rancho 2.5" lift spring, they all have "RR" and various numbers stamped on the bottoms of them.
And after thoroughly wire brushing/wiping down with acetone prior to painting.
And the remainder of the parts, I knew that old recycling bin would come in handy.
Picture of the above parts spread out on the ground. All of these parts bolt on to the frame.
These parts include: sway bar (with attaching brackets/links), engine mounts, front shock mounts, rear cross member/bumper braces, bump stop brackets, front break line brackets, parking break brackets/pieces, proportioning valve plate, cross member angle piece, etc.
After cleaning them up.
I also cleaned up the leaf springs. I spent about twenty minutes on each pack. I did not disassemble the packs, I just painted the assembled packs. Not the best way to do it, but better then nothing.
I used some 5' pieces of electrical conduit as paint holding fixtures for the leaf spring packs. These things are heavy, so only one leaf spring pack per piece of conduit.
