- Dexter
- MI
Along the lines of what Jim posted, but less "bulky"-- what if you simply drill some holes instead of mounting those clevises and make backing plates with nuts underneath the bed to screw in screw-eyes. They could be part of/attached to the crossmembers for support.
You could make/find simple flush-headed bolts/screws/caps/plugs to put in the holes until you need to pop in a screw-eye.
Might not be the most "factory" function, but when they weren't in use, they'd be a lot less obtrusive/obvious than something mounted on top of the bed like these two ideas and wouldn't collect crud like the recesses with the clevises (with use of caps/plugs)
