Postal lift and new tires/rims!!
R U DUN ET?
How you coming on your lift and tires?-JC:D
LIFTED!!!
It's HUGE!!!
Well, not huge, but DAYYYYYYYMN am I a happy freaking camper!
:D:D:D
I've got lots of pics to post, so I'll keep the story brief (well, not really). The rear went together after some grinding on the top of the center pin heads. Installed rear brake line with no problems after liberal Liquid wrench application to get original off. I needed to bleed them anyhow, so the new fluid is a bonus. Then I finished off the rear.
Front was much better with the only trouble being a stuck hanger bolt on the right that only came out after liberal LW hosing,heat and application of the BFH. Anyone know if leaving out the stock/OEM steering stabilizer plate that went between the preing perch and the spring will matter? I cut the mounting stud off it with the intention of reusing it with the lift because I thought that it might be needed to keep the axle level, but when I looked, there was no such spacer on the right side and it measured the same from the axle tube to the bottom of the spring perch, so I left it out. Also, this piece prevented the centering pin from entering the perch at all, apparently relying instead on a couple of ridges in the sabilizer mount to hold it in place (one of which I had cut off already). I think it's fine the way it is now without that plate. I think the axle was unlevel before with it in.
The new brake lines for the front went on ok, although the brake bolt was a pain to get started again, but like I said, the lines needed bled anyway, so the new fluid is good. I cut the wider, outer "lips" of the OEM bushings off to take up the slack on either side of the BDS bushing for the front shackle ends. There was going to be way too much play without them.
Guess that's about it, put on the wheels and set her down, then torqued everything properly. I'm WAY satisfied with the final look, it's EXACTLY what I was aiming for.
I also found out that while the lift kit is 4", saggy-assed springs have negative lift that ought to be factored into the total... I'll let the pictures tell the story on that.
Only problem is that the new front hoses are so long that they bow out and hit the tires. I'm going to have to come up with a spring or something to pull them out of harm's way... any suggestions?
Thanks for all the help along the way guys, i'm rather shocked that I got it all together without having to bring someone in to help out. What a cool feeling to look at it now and be able to say that I did all of that!!! :D Jeeps kick ass.
And to think that this was slowly rusting away in a guy's driveway in Anchorage 8 months ago, unable to start:
Re: R U DUN ET?
How am I doing??? I was writing the post to let you know you impatient bastard!
:D
I's dun.
Here's a pic with the old and new heights for the front right:
(I know I should have gotten down level with the edge, but I was sick of bending over by the time the camera came out :D)
right rear comparison... this is a great picture to see just how horribly flat the old springs were, notice the spring in the background on the left side of the pic.
my very long stainless front brake line that I need to pull back from the tire somehow...
This was my solution for the excess play in the shackle ends of the front springs. i cut the outer lips off of the OEM bushings to make "donuts" that fit on the end of the metal sleeve that went throught the OEM bushings and is now in the BDS springs (you can see it sticking out on the right side). I thought it worked out well and should be a good solution. (blue stuff is all-purpose marine grease)
finally a boring and out-of-focus shot of the new hanger hardware on one of the back hangers. With just very little grinding I was able to get bolts fished through the holes from the old captured nuts using the longer, horizontal frame holes towards the front of the Jeep (easily seen in the picture ~5" in front of the hanger) by fishing picture hanging wire up through the nut hole and out the side hole and then using my part retrieval magnet to actually get the bolt back there where the wire could pull it through. Saved me from cuting any new holes in the frame near the body mount!
Thanks for the update, again how did you get 8" out of a 4" lift??
:D ;) :D ;) :D
sorry, couldn't pass it up;)
You JU-reading bastard. :D
I was thinking though: the difference in tire radius from my 235's to the 33's is 1-3/4" so even still there's a good bit of sag since 1.75+4=5.75" and I still got ~8" :P
So the fact still remains that my old springs were saaagy, just not to as saaaaaaagy as I initially thought. :D
ahh, tou-che' .... you JU posting bastard :D
now, about that math:confused: I see now where it really doesn't add up, are 33's really only that much taller?!
hmm, maybe it - nah, not gonna go there, nevermind ;) :D :eek:
OH, Eric - 'for I get to far from this post - IT LOOKS KICK ASS DUDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:D :D :D
Rush Rush Rush-Hurry Hurry Hurry
What can i say?-I know,Damn that looks good and them old springs must have been some of them 3" slammer springs that those Butt Draggers use:D ;) :D ;) for you to get that much lift-Hell it looks like a jeep now:eek: -JC:cool:
Re: Rush Rush Rush-Hurry Hurry Hurry
I completely agree, that just about says it all right there... :D
Looking good Eric. Glad you got the math part worked out :D :D .
DONE and MOVING!!!!
I'm DONE!!!
I'm DONE!!!
I'm DONE!!!
WAAAAAHOOOOOO! After finally working out my head gasket issue, I got everything back together and (while as nervous as I've ever been) turned the key for the first time with the new lift, tires, brake lines, head and valve cover!!!
It took a bit of cranking but she started up and ran like a champ after settling into a decent idle. Just one tiny leak from a loose hose clamp! THAT'S IT! I was sure there would be something or other that would require me to tear it all apart.
Well, there's not much else to tell, so here's the pictures from the first real 4wd ride EVER for her since I got her! Watching the front tires spin when I goosed her on the ice was AWESOME!!! Mother nature couldn't have provided a more perfect setting for the first ride after it all came together!
good job!
Glad to see everything worked out!!
It looks good with the lift, have fun playing in the ice that got dumped on us!
