tom82cj8
Scrambler Pro
- Austin
- TX
Hey Eric,
I was wondering when the broken bolts would start. I had the same problems on both my CJ7 and CJ8. My suggestion is abandon the idea of using the captured frame nuts. I guarantee that the exposed bolt above the nut has at least 1/16" of rust around the entire circumference and that there is probably no way it will ever come down through the nut. The way I have solved this problem in the past involves a MAPP torch and a BFH. Heat the bolt until it is red hot. Then smack it with the BFH. Usually the nut will break loose on the 3rd or 4th hit. Take some thin but stiff wire and fish it up through the hanger bolt hole in the bottom of the frame and out one of the large side frame holes. Put a grade 8 bolt with flat and lock washer on the end of the wire. Orient it so that the bolt will pull through the hole in the proper direction. Pull the bolt through. Install the new hanger and use a nut and washer. An impact wrench will easily tighten the new bolt and nut. All four of the hanger bolts on the rear of my Scrambler have this setup. The front 3 bolts on my CJ7 near the steering box bracket are also setup this way. After trying several solutions, this is the quickest and easiest fix that doesn't require any special tools. I can take a pic if you would like to see the completed setup.
Later,
Tom
Later,
Tom
