AK-RWC
- south central
- AK
Everything seems right under there including the steering shaft and the steering column.
But when I was driving it, it seemed to be lose and all over the road.
Any help on tightening the steering box?
What do you mean by "tighten{} the steering box?" Sure, there are several bolts that attach the box and brackets to the frame which can be tightened if loose. I actually did have a box come completely loose once; probably was driving that way for 6 months before I realized that I could wiggle the whole box on the frame. I tightened the bolts and was happy. Might have even used some red LockTite.
Aside from that, my dad told me about a trick when I was 16 or 17 that involved the allen-head/set-screw for the sector shaft: tighten it very very very gently. He cautioned me that it's also an easy way to ruin the box. I've been too afraid to try it, and have always heard more about the woes of doing it incorrectly rather than the benefits. Therefore, I've been too chicken to try it. When I built my Scrambler, I just bought a brand new box.
Upgrading your steering shaft will also improve your on-road feel. Consider adding the opposite-side frame brace (several companies are making these brackets now), and even upgrading the OEM box brackets to the aftermarket one-piece bracket which is much beefier. And do all the obvious like checking tie-rod and drag-link ends, and ball joints.
Aside from that, longer shackles and worn bushing can cause a "wandering" feeling. I can't tell from the pics for certain, but it looks like you've got stock or just barely longer shackles, which won't be an issue. The bushings still could be though.
Barring all of those problems, CJs have always been known for loose steering. That's a sexy 8 you've got for a project! I'm jealous!
